Maybe it requires me to look at each model more closely, but I reckon it's quicker to ask here...can someone summarise their FS bikes, Anthem, Trance, Reign, Advanced models of each, X, SX - it's not the clearest what is what (although not as bad as the Kona Process page!)
By category:
Anthem: XC
Trance: Trail
Reign: 'enduro'
Glory: Downhill
The SX tag means the frame is the same but the components are more downhill orientated, eg on the trance sx it gets a pike and monarch plus.
Advanced is just giants term for a carbon frame
Splendid, thanks very much
So the Anthem frame only could be built up to either the regular or SX geometry depending on what fork you stuck on?
Yep. The SX versions tend to have;
Bigger fork
Wider bars
Shorter stem
Phatter front tyre
Added gnar
I recently got an Anthem SX and with 120mm front and 100 rear its a great combination for natural tecky stuff yet still a good climber.
CFH and iainc - do you think it would suit what Im looking for here
http://singletrackmag.com/forum/topic/first-fs-ponderings
Yes. Yes it would.
The Anthem SX is one of the most capable bikes out there. Could happily race mid-field XC on it with the right rider, and then in the right hands could probably take on some enduro-gnar as well. Not a race bike, really. Not overbiked for "everyday" riding, nor is it underbiked for teh gnar!
Very much a bike for just going out and riding. Which is excellent.
Added to the list then.
Just read your other post. I ride similar stuff (based in Glasgow) and for last few yrs have done it all on a Soul. I used to have a 5 but often felt it a bit much, especially on climbs. At age 49 I wanted a bit more comfort for bigger days but no compromise on weight and climbing ability. So far the Anthem SX ticks all the boxes.
Anthem sx would be perfect with the right wheels. So buy a camber evo 29 instead. 2015 colours much better too.
(From a giant fan bar 650b)
Too much choice 🙂
thegreatape - there are a few Anthem SX's in the shops, Dales have a L one I know 🙂
Re Spec vs Giant
Spec is a 4 bar suspension system, so assume soft floaty suspension with a fair amount of movement. Giant's Maestro is a VPP system, and one of the best so assume a good pedaling platform with little movement from the pedals but excellent efficiency on climbs.
Each to their own on preference, I prefer the latter personally and if you enter a couple of events you probably should choose the SX.
My previous FS was a 5, so very different, but I am amazed by how well the Giant climbs. I rarely use the Climb mode on the CTD, only really on fireroads. It spends most of it's life in Trail setting as my riding is generally natural up and down tecky stuff. I did however take it to Glentress the other week and used the Descend settings on the red down and found it great, seemed to have a lot more than 100mm travel on the back and fork o ring was about 10mm from crown by the bottom of the route 🙂Giant's Maestro is a VPP system, and one of the best so assume a good pedaling platform with little movement from the pedals but excellent efficiency on climbs
I'm not a Specialized fanboy but a newer Specialized horst link bike with a platform shock and correct air pressure for the rider's weight shouldn't feel soft and floaty, nor should display "a fair amount of movement" when pedalling or climbing.
The older FSR designs may have had these characteristics (which is why many older Specs had the Brain shock) but they've really got the suspension dialled on the newer ones.
Gotta be honest, the camber is one of the only bikes I'd never ride again. I hated the thing.
