Remember a few posting about these rims a while back and wondered how they were getting on?
I'm thinking of the wider 33mm build. I notice they ate offering hookless beads .. Which is better?
Anyone battered theirs in the alps?
I also see they are developing a 35mm rim
Probably about to buy a set of the 33mm hookless, they're pretty unequivocal about it, makes a stronger rim with no drawbacks apparently.
"For hookless, it is will be much stronger, because the outer layer can go to the rim bed, to make the rim wall sides much stronger.
For the old rims with hook, the outer layer is only reaching at the top of bead, can not go in to rim bed."
Sounds good to me- I don't think you can order the hookless from the website so waiting for one of the Nancys to get back to me with details.
I've got one of the old-process "wider" 26 rims on the back of my hardtail, tbh it's had very little use so far but it's not exploded and fired carbon splinters through my heart...
I've got two of the 'hooked' 33mm wide rims, they're been no problem so far, not hammered them through the alps, but have hammered them in the peak district, no issues yet.
Only one ride on my hookless 29ers so far. First impressions are good.
Do they feel better/stiffer than flows etc?
I've been running the Derby hookless 29" 35mm rims for a few months.
Done a bit of DH racing on them too now, and still in tip top condition. I'm planning on racing a lot over the summer, both DH & enduro, I will continue to use them.
They are noticably stiffer and lighter than a Flow rim. Probably less so on smaller wheels. I'm not so convinced on the benefits of super stiff rims on smaller wheels, a little bit of rim deflection is a good thing IMO. I found on some trails I was slower when running lighter, carbon rims, as they we so stiff, the bike just pinged off stuff.
I cant feel any difference in stiffness, but they do feel 'lighter', they're easier to accelerate up to speed.
Lots of people do say that they feel massively stiffer though, so I suspect I just dont have enough finesse to detect a difference.
My 33mm wheelset, albeit with old-style "hooked" beads are currently at Coventry airport in customs clearance 😥
Can't wait to get them and shed a tonne of weight from my wheels - OK, not a tonne, but over 550g 8)
Have also ordered some accurate scales so that all of my calculations are shot down in flames....
Proutster.. What hubs and spokes did you go for?
I've got some of the hookless 29er rims, very impressed so far. Built nicely, stiff, not exploded.
Come on people.. Where's the pics?
They look like boring black rims!
Black Hope Pro 2 Evo (40T engagement) and the black bladed Pillar Aero X-Tra spokes.
Fully murdered-out, innit!
Proutster, how long have we been waiting for you to get these wheels done? FFS man.
Chinese New Year - rubbish time to order! Plus then they had to wait for the 40T hubs.....
Should be on the bike in time for my first Enduro race at the end of March and then for our Wales trip in April (that's if they haven't exploded into a fireball by then).
All part of the plan (I've got all of the bits ready to go on) to reduce the Reign down to below 28lbs - but that's a pre-accurate scales calculation....
The bike, with 160mm Pikes up front, should be pretty useful then - pity it'll be let down by someone who'll be happy not to finish last 😳
thinking of pulling the trigger on them too, good exchange rate at the mo. A Nancy says they are available now and sent me the rim profile. Pretty sure hookless is the way forward, the more I think about with tubeless rims and tyres the bead hook plays little part in holding the tyre on.
http://singletrackmag.com/forum/topic/anyone-running-bead-hookless-rims
I've recently acquired a pair of 33mm wide rims. Built on Pro 2's. Had a few hard rides on them in the rocky NE of Scotland. So far so good. They definitely feel different to alloy rims.
[img]
[/img]
The rims were bloody hard to get tyres on though. Had to use levers. Haven't had to do that since trying to fit 4 ply Intense tyres to my old Deemax rims
I've just ordered a set of the 33mm 26" rims in DH flavour (460g) I'm pretty sure they are only doing these in the Hookless profile now from what Kartrin Li said in her email last week.
Current build time is 7-13 days and 4-7 days shipping.
I was going to have a set of wheels on Pro2's however they could only offer DT revs or the Pillar bladed spokes so have opted to build them over here with Brass nipples and DT comps. Hoping they will strong enough to survive whistler later in the year!
About to order some rims too, just wondered which is the preferable weave for lardy riders?
Weave is just a cosmetic outer layer - it makes no difference to strength of the rim.
Gee - Cheers.
So are they just running yellow tape and a valve?
messiah, what rims are they 650b?
Do you think it's cheaper to get them to build with pro2's or just order rims and build in the uk?
I found Schwalbe Tubeless Ready tyres way too loose with one layer of (Stan's yellow) tape - added a layer of Gorilla tape over the top, went up straight away then.
Mine (Wider, old process) is just yellow tape, tbh they really didn't look like they'd work so I was a bit surprised.
I've got some 35mm hookless 29er rims on order. Not turned up yet, presumably LB are on catch up after new year. Also have some DT240's (provided the colour is right in my head - white hubs on an all black bike ok????!!!) and revs ready to go... provided the ERD suits.
Anyone running the 35mm hookless 29er rims care to comment on the actual ERD?. Is it as specified?. They used to vary a wee bit although I think LB tightened up their ERD consistency more lately.
What tyres are folks running with these wider rims too!. I'm wondering whether I might downsize to a 2.1 or 2.0 for lower weight and maybe to make sure the tyre will still fit in stays!
Not the 35mm ones, but on the standard hookless ones all my spokes came up too short using their quoted ERD. I didn't measure, but I'd be inclined to do so before ordering spokes.
hmmm feared that might be the case but it might still work just. At least I can remedy that with bigger nipples 🙂
[b]kimbers[/b]messiah, what rims are they 650b?
It's a 26" and 33mm wide. [url= http://www.light-bicycle.com/New-26er-33mm-wide-enduro-MTB-all-mountain-downhill-carbon-rim-tubeless-compatible.html ]Linky[/url]
Warranty replacement fot the 28mm wide one I broke at the Trans-Savoie in August. I've not built it up yet as I've been 29er-ing recently.
I was never sure but I think mine was under the claimed ERD- I went down a couple of mm from an old rim and reused spokes but with 2mm longer nipples, it should have been a pretty neutral change but in the event was right on the limit. Equally, I might have mismeasured the old rim. But anyway I would measure the rim before ordering spokes!
Yeah it's not insurmountable, I used the spokes (and 12mm nips) I'd ordered, but it was harder than it needed to be to build, and even when fully tensioned there's still a couple of threads visible on some of the spokes. I wouldn't be happy building them for someone else, but for me they're fine. If they all break I'll just buy longer ones!
Doh, I meant shorter nipples btw.
No worries, know what ya meant NW 😉 - thanks for your help before btw.. still a bit confused by it all now!.
Aye I have some spokes in stock so to speak but will hang off ordering anymore prior to receiving the rims I think. Already have plenty of 14mm nips so should be ok if they come up a bit shorter.
I did push for a lighter batch so with less material in them they might come up with a larger ERD. Will have to see... wish they'd hurry up and get here. Think an email to Nancy is coming on.
Really curious about the tyre implications too.. sad but quite exciting 😳
My first set of LB carbon rims were spot on with the ERD so maybe I shouldn't worry to much yet 🙂 As said measuring first is safest tho.
By the way if anyone wants to avoid the PayPal direct charge when ordering I suggest going through the LB ebay site. The newer hookless rims are listed there too.
Here's the ebay linky for those interested....
... wish i was on commission 😥
Spokes won't break because they're a bit too short.
Cheers njee
You know what I mean, more likely to be the (alu) nipples breaking, point was still the same.
I've had wheels similarly built go on for years. Especially under a lwt like you 🙂
so what does each rim work out at £127 excluding import duty? (for the $170 rim)
Aye, sure they'll be fine, hence why I proceeded with the build 🙂
That's gonna depend on the exchange rate... Google reckons £101 currently.
I was adding on the delivery ($43)
Are folk successfully running these tubeless? Does it require more than just yellow tape? I appreciate that this can vary with tyre brands - I tend to run Maxxis Minion EXO 2.5, so any information about compatibility with Maxxis tyres would be appreciated.
Reading on mtbr.com it sounds like a lot of people were using Bontrager rim stips, I'm not sure how well this would work on these wider rims.
Im using stans downhill rim strips on mine, the narrower strips dont fit. they went up really easy, which is more than can be said for fitting the tyre itself, it was pretty tight.
Hmm I don't see the 26" ones. How much is the paypal fee?
Paypal fee is $13.65. But the shipping's $3 more expensive so it's about £6 more to buy off their website than from ebay. There's hookless 29ers I see but not 26ers because we're obsolete and pointless.
Messages on their website say the 26 hookless went into manufacturing at the end of feb and they are already taking orders so they should be up soon...
Yeah, they're available, just not yet fully listed. Just ordered mine! See if I can get them built before Proutster.
Northwind
Pretty good chance - still "awaiting customs clearance" 😥
Just got an update for Light Bicycle. Mine are still waiting to be built 🙁 At least the weather will be a bit better when they arrive.
It appears mine have finally set off too... Wohoo. It's only been about three weeks since ordering but I did press for a lighter batch and 28 holes.
Almost getting excited!!!
MB ran my last set fine with yellow tape. Went up a treat. Will have to experiment with the new uns I guess, should b feet!
proutster - MemberPretty good chance - still "awaiting customs clearance"
I'll bring mine down in April, you can see what you could have won
I'm waiting on a set to be sent to finish my enduro.
29er, 35mm hookless on hope hubs.
I initially wanted some derbys but he's out of stock atm.
I did ask if they ccould make them with a sealed rim bed so they'd be fully UST but was told that the rim depth wont allow for this.
So I'm guessing stans dh tape is the one to use?
stans DH strips work fine on the 33mm rims, I guess they'll also be fine on the 35mm rims, but havent tried it.
NorthwindI'll bring mine down in April, you can see what you could have won
Stop rubbing it in, still awaiting customs clearance - could be up to 7 days, so they've just said 🙁
Just as a quick note the 33mm wide rims are still available in both 'hooked' and 'hoodless' rim profiles so be sure to specify when ordering if doing it through the LB website as they only had the clincher type up when I order and I had to go back an specify I wanted Hookless as they are a different part number.
think I'm going to do it... hookless.... 8)
Very interested in a pair of these for my 29er hardtail for XC use... Which rims would be the recommendations of the collective?
I'd get (rather I got) the [url= http://www.light-bicycle.com/bead-hook-less-rims-carbon-29er-light-bike-rim-tubeless-compatible.html#.Uxmu2mJ_sgc ]Light Hookless jobbies[/url]
Our group has just ordered 6 of these rims. Interesting comments on the mis-quoted ERDs. Think I will hold off getting spokes until I can measure them myself.
and
more at http://www.flickr.com/photos/59684834@N08/sets/72157638740866764/
The ERD was spot on on mine, built up with Cx-rays and Hopes, 20 & 142 (40t). They weigh the same as my Crossmax SX did but I'll warrant they are stronger and will hold true for longer. And yes my tyre profile is now about 5mm wider. They hold a lot more at steper lean angles than they used to do.
If those who built up 33mm 26" on Hope hubs could post their spoke lengths that would be great, I'll measure anyway but would be good to have a reference. Also what length nips are people using?
Wow.. They look like fat bike tyres!
@J273 No link sorry.
I just emailed Carolin with my specification and everything was a 'go', apart from the tubless rim bed. Its doable on the 26, 33mm but not these 29, 35mm.
I'm being told by my lbs that ENVE tubless tape is basically gorilla tape~printed, and to use This....
One thing i didn't think about when ordering is straight pull or j bend hubs.
Apparently straight pull are stiffer for 29.
Have i missed out by buying j bend?
sq225917 - bike looks fantastic.
What spoke lengths did you use?
Are CX-Rays tougher than DT Revolutions?
They have a higher fatigue strength yes.
If you use with alu nips that just means that nipples break instead of spokes, with the same net effect (experience talking).
Unless you break a lot of spokes I'd get (have got) Revs.
Tonka Toy!
They look super Phat.
I'm wary of Revs at my weight (about 100kg)
Wouldn't use Alu nipples - do you have to use them on CX Rays?
How does the tyre width come up on the 35mm hookless rims compared to a Flow EX?
[quote=honourablegeorge ]I'm wary of Revs at my weight (about 100kg)
No reason not to use brass nipples with CX-Rays. Then again, no real advantage to them over Revs on a mountain bike - they're effectively the same thickness and hence the same stiffness, so will build up just as strong a wheel. In theory CX-Rays have better fatigue strength as njee says, but in reality that shouldn't be an issue with a well built wheel. If you're wary of Revs because of your weight (they will build a less stiff and less strong wheel than DT Comp or Sapim Race) then exactly the same issues apply to CX-Rays.
Can anyone explain hookless to me? How does the tyre stay on? Do you need proper rim strips? Do you need proper UST tyres?
Their fat bike rims are nearly ready now.
90mm, double wall, 650g. Shame they aren't 550g or so.
Square profile.
Thinking about a set of these for a SC Superlight to replace Hope Hoops with Arch EX rims.
The main reason is that I want to put the Hopes onto a HT build and as the FS is the main bike it is getting an 'upgrade' if they are deemed to be so.
I'm a little worried as I am 110KG and although don't ride DH or jump around, I do hit things quite hard occasionally (mainly through too much speed as against talent ;o) )
The Stans rims are coping fine so I think the LB rims should be ok, but I'd be interested to hear peoples thoughts before I press the buy button.
Am thinking of the 33mm hookless with their spokes to build up onto a spare pair of Pro 2 hubs in my parts bag.
