About to grit my teeth and get the drill out...Frame is a MK1 Codeine 29er, I am just trying to work out best location to cut the hole...
Anyone here with a Codeine drilled it for a dropper? If so where exactly? I am thinking in the seat tube about 5-10 cm above the main pivot
What says STW?
Post up a pic if you can mate? So people might be able to give a clearer idea?
Drilled mine last year, I'll post a picture up for you.
Cheers gibbonarms, much appreciated!
https://www.pinkbike.com/photo/16520562/
https://www.pinkbike.com/photo/16520560/
I drilled two 5mm holes then filed through with a round file, then filed in the direction of the cable hose and cleaned off with some fine grit. The worst part of the job was cleaning the drilling swarf.
Awesome- cheers Mr Gibbon, you're a star.
