Lucky old me, life seems to have presented me with the opportunity to get a hardtail for zooming about duties. The alley Bizango is hard to beat and is a favourite here, but I see that Halfords/Cycle Republic now have a CF version for £1000.
A new frame from what I can see. Spec looks decent, weight looks ok too- but of course, there are no reviews. Anyone in STWLand rode one yet?
not sure why the voodoo is liked so much. thought it had a 1 1/8 straight steerer headtube.
Not yet (missed my c2w windown, next is in Jan), they did send me the geo chart though: https://imgur.com/a/GXm9cJ0#mGe1aTv - it's not just a copy of the alu one.
Alu is straight steerer, carbon is tapered.
I think the standard fork is a 1 1/8th straight steerer, but the frame has a 44mm straight headtube. You should therefore be able to run an external lower cup headset to run tapered steerer forks.
Geo is very very close to a chameleon in Large, without adjustable chainstay length. should be good!
Was going to warn people about the warranty but looks like they're doing a lifetime one on frames now, was only a year when my Bizango cracked!
Looking at it again, I suspect they came up with the bright idea of an affordable XC/trail carbon frame then someone decided it had to be under £1k for C2W.
Shame there's such low-end kit on it. They should do a £1.5k version with a Reba or Rev and SLX groupset (or similar).
I'm happy with my alloy biz. Only thing I've done is add a dropper, wider bars and swapped the wheels for some superstar/wtb from the October offering and decent pedals. Does me perfectly just general xc and long days in the saddle stuff without much tech. Fork gave me some issues after 3 rides, lots of stiction which went after a lower leg service (they are grease and not oil lube)
The spec on the carbon doesn't lot horrendous, I love the colour but the way the the chain stays drop down looks odd
https://www.mbr.co.uk/news/voodoo-bizango-carbon-392370
I plan on buying one, although like said, unfortunately no higher end version or frame only option.
Tire clearance still unclear, but looks to be unclear. If anyone has one please let us know and also your thoughts on sizing.
I bought one after researching the Bizango although I could find any reviews on the carbon. I got a scrap bike from the tip and used that to get a 20% off trade in at Halfords so it only cost me £800.
A few things to note having checked against the spec and changed the tyres:
The frames are not the size they state on the website. For instance I got a medium and it is not 18" but 17".
The front wheel is not quick release as stated
The Brakes are 180mm front and 160mm rear (not 180 rear as stated)
The rear tyre is the race version.
I changed the tyres to Minions and found that a 2.3" is the biggest you will get on the rear. You could go larger on the front but the rim width probably isn't suitable. They do have Tubeless rims and I went to go tubeless but didn't have any rim tape and the original isn't suitable.
The bike feels great to ride but I am no expert in bike reviews. I have the front forks at 90psi which according to the side is too soft for me at 90kg but I am only using 3/4 of the travel. Perhaps the sag is too much and the compression damping is too hard but I haven't looked into it much and only ridden it for a few hours so still getting used to the feel.
I have some photos I can try and share but I am offshore so difficult to get onto photo sharing sites with the firewalls in place.
The frames are not the size they state on the website. For instance I got a medium and it is not 18″ but 17″.
The rear tyre is the race version.I changed the tyres to Minions and found that a 2.3″ is the biggest you will get on the rear. You could go larger on the front but the rim width probably isn’t suitable. They do have Tubeless rims and I went to go tubeless but didn’t have any rim tape and the original isn’t suitable.
The bike feels great to ride but I am no expert in bike reviews. I have the front forks at 90psi which according to the side is too soft for me at 90kg but I am only using 3/4 of the travel. Perhaps the sag is too much and the compression damping is too hard but I haven’t looked into it much and only ridden it for a few hours so still getting used to the feel.
Great deal for 800,-. Thanks for letting us know the tyre clearance. Would be a pity they reduced tyre clearance by going to 425mm chainstays in stead of 435.
If you do manage to get some photo's out, please include some of the space between the tyre and the frame.
As I am away offshore I can not take any new photos but here are the ones I have taken already.
https://flickr.com/photos/166000635@N05/sets/72157711587831068
Thanks Tark. Good looking bike I think.
Nice looking bike.
Fence is up to scratch.
Yard needs weeding
I got an aluminium one, 5 years ago. Upgraded with my 26er drivetrain, saddle, bars. Then I got some Superstar wheels, then a Reba.
When I got the Solaris it became singlespeed.
It proved a great way into 29er.
Shame about the rear clearance but it looks ace otherwise
Agree, looks nice. A 2.3 Minion is a 58mm tire. If there was still a little room for a 60-61mm, it would be enough for me.
Size L is sold out for the moment, probably they'll get a new shipment within a few weeks.
There is an article on the homepage:
https://singletrackmag.com/wp-content/uploads/2019/11/voodoo-bizango-carbon-1000/
They probably didn't see this thread, before posting it.
If anyone got a change to get a photo of the tyre clearance, that would be awesome.
does it have internal dropper post routing though? I can't see the usual bottom bracket avoiding ports....
Certainly doesn't look like a "cheap" bike. A bargain at £800 with the trade in. Size wise it compares to the Chameleon. I have an ally medium and its 17" I tried the lard and it felt a lot bigger im thinking it must be closer to 19"
Shame about the tyre clearance would have been nice to able to squeeze a pair of plus wheel into it and run some 27 x 2.8 rubber.
I am back from offshore now so took some photos of the rear tyre clearance with the 2.3" tyre:
[url= https://live.staticflickr.com/65535/49142088743_9e7dd90b75_k.jp g" target="_blank">https://live.staticflickr.com/65535/49142088743_9e7dd90b75_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hSw3U8 ]Tyre Clearance[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
[url= https://live.staticflickr.com/65535/49142088753_087e93d7a0_k.jp g" target="_blank">https://live.staticflickr.com/65535/49142088753_087e93d7a0_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hSw3Ui ]Tyre Clearance[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
[url= https://live.staticflickr.com/65535/49142088758_67c2901493_k.jp g" target="_blank">https://live.staticflickr.com/65535/49142088758_67c2901493_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hSw3Uo ]Tyre Clearance[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
I also fitted a dropper today. Has internal routing using the same path as the rear brake. PS before anyone notices, There was an additional bush for the nipple on the bottom of the dropper missing in that photo but it is fitted now.
I ran the cable down the tube and using a spring loaded pincer thing pulled the wire up the seat post tube.
[url= https://live.staticflickr.com/65535/49142791742_1b5c86fa9c_k.jp g" target="_blank">https://live.staticflickr.com/65535/49142791742_1b5c86fa9c_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hSzDSN ]Dropper post routing[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
[url= https://live.staticflickr.com/65535/49142791802_532d8291e9_k.jp g" target="_blank">https://live.staticflickr.com/65535/49142791802_532d8291e9_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hSzDTQ ]Dropper post routing[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
Thanks. Looks great- a 2.3 is plenty, really.
How does it feel overall? Does it feel light enough to you?
Thanks a lot Mark, that's very clear and useful. In the second photo it almost looks like there's a small recess in the chainstay for the tire which seems not exactly in the right spot.
That is exactly what I thought. I did wonder if different tyres had a different side wall height which would make a difference.
I am not very good at giving feedback about the bike as it is the first and only 29er I have ever ridden but it feels ok to me. Also coming from a Steel Frame Rock Lobster I am not best placed to comment on its weight.
I can if you wish get on a set of scales with it and find out how much it weighs with the bigger tyres and dropper post.
I got a 150mm dropper and its just about spot on. It was getting dark by the time i finished messing about with it so will take some photos in the day today.
What kind of weight is the frame do we know?
[url= https://live.staticflickr.com/65535/49149017327_4610faa0fb_k.jp g" target="_blank">https://live.staticflickr.com/65535/49149017327_4610faa0fb_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hT8ywt ]Untitled[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
[url= https://live.staticflickr.com/65535/49148807426_838972a0b3_k.jp g" target="_blank">https://live.staticflickr.com/65535/49148807426_838972a0b3_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hT7u8u ]Untitled[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
[url= https://live.staticflickr.com/65535/49149017292_1c4e3cf69e_k.jp g" target="_blank">https://live.staticflickr.com/65535/49149017292_1c4e3cf69e_k.jp g"/> [/img][/url][url= https://flic.kr/p/2hT8yvS ]Untitled[/url] by [url= https://www.flickr.com/photos/166000635@N05/ ]Mark Talbot[/url], on Flickr
Looks great. Love those BrandX droppers, I've fitted and used a few with zero problems.
Interesting to read that you're coming from a Rock Lobster as I too used to have one, great bikes.
Once again I'm amazed at how official studio shots make a bike look rubbish compared to a few pics taken by the owner in their garden where it looks great!
Says on the website that the M and L will be in stock again in January. Geometry now listed as well.
If they would wanted to change the location of that recess, they would most likely have to redesign the bottom bracket area mould. That's more than just a running change. Probably cost prohibitive.
2.3 is not too bad, just that 2019 you would hope for a bit more for something that otherwise looks very contemporary and well thought out.
I complained to customer services as I ordered the medium thinking it was 18" which is what was originally on the website but after seeing the geometry posted above on this thread I contacted them to say I wasn't happy with how small my frame was and wanted to change it for a large and that the website was incorrect about the sizes (amongst other things like the rear brake size and it having a quick release front wheel). They said they would get back to me but never did but not the geometry is on the site and I have now changed tyres and fitted a dropper post which I suspect will be too high at fully extended if I got the larger frame.
How much is the collar of the dropper above the seat tube? If it is 3cm or more, the larger site would fit (42 vs. 45cm seat tube).
How tall are you?
I complained to Halfords when they sold me a Boardman CX with eyelets for guards, which didn't exist. Then they removed the mention from the website.
Only got a satisfactory outcome as it also had a paint fault as well.
I'm just under 6 foot. I haven't measured the seat post but its not far out as you can see by the photo above. 3cm could just be manageable but I am not holding my breath as the bike has been used a handful of times now including a trip to the top of Helvellyn so I can't see Halfords wanting to give me a new one.
https://www.mbr.co.uk/reviews/hardtail/voodoo-bizango-carbon
Quite positive first impression. Good ride comfort.
