Hi,
My left shifter on my road bike has a rattle from a slight bit of movement. If I put my finger on it and pull it back (opposite way to pulling the brake on) it stops rattling.
Is this just worn and there's nothing I can do about it or is there something I can tighten or replace?
Thanks
There's a wee plastic bit that sits at the top of the lever that can come loose. Pull the lever to reveal a wee philips head screw that fixes it.
Hope that sorts it.
I have the same rattle. I put some wee 5x5x2mm sticky pads inside (on top of that philips head screw), but it hasn't really improved things. Open to ideas...!
Lol, I have lost that screw before but I've already checked it this time.
I'll try some tape
My old set did that and I made it go by not having the reach all the way in, just a tiny little out sorted it out.
Maybe check what the reach is set at?
Fixed it! Thank you!
Didn't even realise these brakes (ST-RS685) had reach adjustment. Manual here in case anyone else didn't spot this 2mm hex screw...
No worries! Was really doing my head in on mine
https://m.youtube.com/watch?v=1GbAdx_Ozhs
OK, I've watched the video, I'll try this. I'll let you know. Thanks everyone.
@ojays not only has that fixed it but the brakes feel better. Its a good job I have big hands and didn't need the extra reach. Thanks
