Rockshox 35 gold tr...
[Closed] Rockshox 35 gold travel increase
8 Users
I'm looking to upgrade my forks to Rockshox 35 gold, ideally I wanted 130mm travel but I can only find 120mm in stock anywhere on the market.
Is it possible to increase the travel on these forks? I know it can be done with the more expensive forks rockshox do.
Thanks
Posted : 07/03/2021 8:10 am
Page 23
Looks like they use spacers rather than different length shafts so it should be a cheaper upgrade.
Posted : 07/03/2021 9:29 am
They have all travel spacers in the air shaft.
As long as they are 10mm ones as per the service drawings it should just be a case of removing one to extend the travel 10mm.
Posted : 07/03/2021 2:20 pm
Hmmmmm.... interesting. The question I have now is will increasing travel lengthen the fork and change the geometry? I'm hoping yes as this would be perfect for the frame I want to buy.
Posted : 10/08/2021 9:50 pm
Yes
Posted : 10/08/2021 9:51 pm
Even though it's still using the same air shaft? Clever, unexpected and bloody amazeballs. I assumed it would just allow more travel without changing length.
Posted : 10/08/2021 9:54 pm
The spacers prevent the air shaft from extending fully, so limit travel by holding the fork down. They're not the same as bottom out spacers.
Most forks used a similar system until a few years ago.
Posted : 11/08/2021 7:36 am
I would google the 35s before buying. There is a big thread on MTBR about how poor they are.
Posted : 11/08/2021 7:41 am
I have some 35s in my garage. Came on a Scandal at the start of the year. Used for a few months before I swapped them out.
Set up at 130mm. Drop me a pm if interested in second hand. Will get details together.
Posted : 11/08/2021 9:37 am
I've already got the 35s Scandal, just need to extend them if I buy a Bird Aether 9 frame.
Posted : 11/08/2021 10:34 am
I already have the 35s on my Scandal, just need to extend the travel if I buy a Bird Aether 9 frame
Posted : 11/08/2021 10:35 am
I don't think there's much surprising in there? From the off they made no attempt to hide the fact it was a cheap but big fork to sit below the Yari. If you want a Yari, get a Yari!
The only bit that's news to me is that the lowers aren't the same as the Yari (unless the bushings are the same in the Yari/lyric).
I've not had any issues with mine. It was OK out of the box and quickly loosened up to become good.
It's not a Pike/Lyric, but on a hardtail at least it's controlled/fast enough that I can't out ride it.
Definitely a lot better than the Sector (which was a re badged original Pike) which was my last experience of a cheap RS fork.
Posted : 11/08/2021 11:18 am
