Missing & bent ...
[Closed] Missing & bent cassette teeth - Is it really 'Normal' wear and tear?!
14 Users
My bike is currently back for warranty inspection for a frame issue
I also reported the broken shifter * which they have said SRAM will likely warranty
I have also reported the GX eagle casette for 3 missing teeth and multiple bent teeth, they have said SRAM will likely say this is 'normal wear and tear'.
Now I undertand wearing parts will wear, thats what they do, BUT are missing and bent teeth really normal wear and tear and to be expected? ** Because apart from this it would have life in it yet, but it won't shift properly like it is
I realise the cassette is nearly two years old, but its still just on its second chain (having swapped at 0.5% 'stretch' *) having been ridden on average once a fortnight on 15-25km rides, the brunt of the pedalling going up fireroads
Posted : 21/05/2020 8:08 pm
Sram cassettes(high end ones) are made from Swiss cheese !!
Posted : 21/05/2020 8:10 pm
Bent and broken teeth are poor and if it was two months old, you could try for a warranty. However, I'm not surprised they don't think you'll have much luck with a two year old consumable.
Posted : 21/05/2020 8:12 pm
[url= https://live.staticflickr.com/65535/49920762397_756af1558d.jp g" target="_blank">https://live.staticflickr.com/65535/49920762397_756af1558d.jp g"/> [/img][/url][url= https://flic.kr/p/2j4jXrX ]CassetteBentTooth10[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
[url= https://live.staticflickr.com/65535/49920464056_9a6390bdd1.jp g" target="_blank">https://live.staticflickr.com/65535/49920464056_9a6390bdd1.jp g"/> [/img][/url][url= https://flic.kr/p/2j4iqL9 ]CassetteBentTooth7[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
[url= https://live.staticflickr.com/65535/49919950848_d8f476ecd1.jp g" target="_blank">https://live.staticflickr.com/65535/49919950848_d8f476ecd1.jp g"/> [/img][/url][url= https://flic.kr/p/2j4fNcJ ]CassetteBentTeeth45[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
[url= https://live.staticflickr.com/65535/49920461041_46d90d3e82.jp g" target="_blank">https://live.staticflickr.com/65535/49920461041_46d90d3e82.jp g"/> [/img][/url][url= https://flic.kr/p/2j4ipSa ]CassetteMissingTeeth5[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
[url= https://live.staticflickr.com/65535/49920468756_9892804bc0.jp g" target="_blank">https://live.staticflickr.com/65535/49920468756_9892804bc0.jp g"/> [/img][/url][url= https://flic.kr/p/2j4isab ]CasetteBentTeeth2[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
Not normal wear and tear but no way is that a warranty issue at two years
Posted : 21/05/2020 8:14 pm
A quick google suggests it does happen, but as you say but those I've seen said to have been warrantied have been much newer. I've never seen this on a cassette before and I've ridden a lot of cassettes all the way to very worn out before. Its the completely missing teeth that have me baffled?
*I had to buy another shifter at short notice over a year ago, that broke a couple of months ago and that got swapped out there and then in the shop I bought it from. (Both of them the shifter internals have just gone bang and won't upshift (big paddle)
SRAM officially claims a two year warranty on it
*on a park tool tool, yes I know sheldon brown says they are completely inaccurate. When you measure 'correctly' over the number of pins, I find a park tool style overreads by about twice, so really I changed the first at and am nearly at 0.25% chain stretch on the second chain
Posted : 21/05/2020 8:19 pm
two years is a long life for a cassette and it doesn't look like you maintain your bike very well
Posted : 21/05/2020 8:20 pm
"Not normal wear and tear but no way is that a warranty issue at two years"
Which is it?
"doesn’t look like you maintain your bike very well"
In what respect?
Posted : 21/05/2020 8:21 pm
To me that looks like an impressively well used and well worn GX cassette. I've got a number of them on different wheels of varying age and mileage. Now I think I must get out more and do more miles and change cassettes less often.
Posted : 21/05/2020 8:33 pm
To be fair, your flickr feed is full of broken bits and wrecked gear...
Posted : 21/05/2020 8:35 pm
james
Member
“Not normal wear and tear but no way is that a warranty issue at two years”
Which is it?
abnormal wear and tear but can you show its a manufacturing fault? Or is it down to something else? Poor mainenence, stones getting trapped in it, being fitted with a rock? Cack handed shifting?
Posted : 21/05/2020 8:44 pm
I suspect that as the teeth wear normally they become more at risk of breakage due to the steel thinning and the loads becoming more concentrated.
Posted : 21/05/2020 8:47 pm
It’s worn out anyway.
"To be fair, your flickr feed is full of broken bits and wrecked gear…"
I largely only ever use it for hotlinking onto here ..
"It’s worn out anyway"
Thats nothing on the amount of wear I've got out of shimano cassettes over the years
I can't show its a manufacturing fault no, I just don't think teeth snapping like this is normal?
Yes it has had to endure some dodgy shifting. Its never shifted perfectly from new despite trying swapping hangers/rear mechs. (yes i use the red plastic mech setup guide)
How do you maintain a cassette exactly? Does mud contact snap teeth clean off?
And no it has never seen a rock.
Posted : 21/05/2020 9:16 pm
James - the point is it could be any of those things. It may be, it may be something else
Warrenty on a two year old cassette on its second chain - I wouldn't even try
Posted : 21/05/2020 9:22 pm
I was unlikely to get round to bringing up the shifter. Its only because I had to get the frame sent in that I mentioned the shifter let alone the cassette. Just a bummer as casettes aren't exactly £30 anymore ..
Posted : 21/05/2020 9:27 pm
 tdog
Is there a chance poor bike hygiene to blame, either that or you have legs of Iron
Posted : 21/05/2020 9:30 pm
That cassette is ****ed .
And that's before the broken and bent teeth.
It's plain ass worn out . You may have got X more years out of because your willing to put up with the din of poor meshing but its beyond useful life span.
Posted : 21/05/2020 10:17 pm
Well, my everyday bike, which saw use on the (often muddy) TPT most days, went through a cassette in about one year.
Posted : 21/05/2020 10:19 pm
The design of that cassette means that the teeth become weak as they wear, the cutouts mean the supporting bridges get weaker. That cassette has a lot of wear on it, also a lot of rust. The bent teeth could be due to poor shifting caused either by the shifter or mech being worn or just bad technique, shifting under power for example. I'm not saying it's your fault but that cassette is well past it's best.
The fact you say it's mainly ridden on fireroads suggests a gritty surface which will wear out a drivetrain fast. Very much doubt anyone would entertain a warranty claim on it.
Posted : 21/05/2020 11:53 pm
Genuine kudos though op.
My bike is immaculate but it's because it's probably not ridden a huge amount compared to yours.
Your using the bike for what it's meant for. Good stuff imo.👍
Posted : 22/05/2020 12:07 am
I realise the cassette is nearly two *** years old
It's worn out.
Posted : 22/05/2020 1:19 am
"either that or you have legs of Iron"
Lots of people make a point of pointing out my calves?
"mainly ridden on fireroads"
Brunt of the pedalling on (steady) fireroad climbs. That bike mostly does free-wheely descents
I can see a strong consensus in this thread so I've had my query answered thoroughly thank you
I'm left wondering how people get through 4/5/6 chains over the life of a cassette when thats had two to 0.5%
I'll finish with a shimano cassette I once wore WAY further than I have any other ..
[url= https://live.staticflickr.com/65535/49923715578_0c6d07dfc5.jp g" target="_blank">https://live.staticflickr.com/65535/49923715578_0c6d07dfc5.jp g"/> [/img][/url][url= https://flic.kr/p/2j4A6jS ]IMG_20180909_150139[/url] by [url= https://www.flickr.com/photos/29214358@N08/ ]james74747474[/url], on Flickr
Posted : 23/05/2020 10:08 pm
That's a SRAM cassette, even says it on the end! It's also a 9 speed which has a much higher tolerance to being worn. The letters be and au are SRAM codes, Shimano has HG on them. It's not even that worn either!
Posted : 23/05/2020 10:20 pm
Looks like a Shimano cassette with a SRAM lockring.
AU appears to refer to a specific HG70 cassette?
Posted : 24/05/2020 10:30 am
