'Lazy' SRAM brakes ...
[Closed] 'Lazy' SRAM brakes when it's hot outside?
13 Users
Anyone had this? With the hot weather, I've noticed my SRAM Level TLs - especially the rear - get sticky.
The lever won't return fully. I'm guessing the pistons aren't retracting completely. Only happens when the bike has been in the hot shed - once I get going and things cool down a bit then it gets better.
Well looked after, recent pads, been bled recently.
Posted : 26/06/2020 9:32 am
my mates one do this apparently. I've not experienced it with mine but i've only had them for a week or 2!
my old oro`s do teh same. i presume its the lever material expanding and tightening up the seals.
Posted : 26/06/2020 9:34 am
 nuke
Yep, had to drag my bike with Codes out the hot shed the other day...both front and back. Cant recall it with my other SRAM brakes (Juicy & Elixir)
Posted : 26/06/2020 9:35 am
'They all do that, sir'
Will known issue, the plastic plunger in the lever swells in the heat apparently. You can remove it and sand slightly for more clearance, or but a replacement metal one from eBay.
The Level Ts on my jump bike do it really badly in the heat.
Posted : 26/06/2020 9:36 am
It's probably a master cylinder piston sticking (in the lever end). Had this on some Guide RS and googled it - it's a thing...!
Replaced the pistons with new units, which were 0.15mm less in diameter. No more sticking brakes in hot weather. Then I sold the bike.
Best option - junk the SRAM brakes and get something decent!
Posted : 26/06/2020 9:38 am
My girlfriend's Guides have started doing this and I haven't gotten around to investigating it yet. Both levers are sticky but the rear won't return at all and stays floppy. This is nothing to do with the heat because the garage is like a walk in fridge.
So it's the pistons in the lever is it?
Best option – junk the SRAM brakes and get something decent!
That's what I've always done in the past but I've spent a small fortune on lockdown toys so far. I might have to see if the mrs. will pay half for some E4's since it's her bike.
Posted : 26/06/2020 9:40 am
I see this trotted out a lot. It's bollocks. Especially if you've had to replace multiple Shimano callipers.
Modern SRAM brakes are great, especially the Bleeding Edge system.
Posted : 26/06/2020 9:42 am
@submarined - I said decent, not Shimano. They used to be good, but I have also had to replace callipers on the 'new' XTs (8000 series on the SO's trail bike).
Have never come across decent SRAM brakes (but bizarrely my SO's Avid XO Trail on her enduro bike are great).
I run Hopes - not the most powerful, but reliable and very easy to live with. And not that I've had to, but can get complete service kits for every part.
Posted : 26/06/2020 9:48 am
It's only been the last couple of days I've noticed, so a plastic piston in the lever that expands in the hot shed makes sense.
Not a massive issue, they soon cool down. Been pretty good otherwise, impressed with them.
Posted : 26/06/2020 9:49 am
Some people file down the plastic plungers though the alloy replacement plungers on eBay cost about £8 and work great, will transform a lazy brake. Hardest part of swap is getting the circlip out of the lever.
Posted : 26/06/2020 9:55 am
This is 100% the solution to this. I think SRAM may have fixed this on newer brakes, but the older ones (E.g. my 2015 Guide RSCs) suffer with this. With heat, the plastic piston expands very slightly enough to get 'stuck' against the piston bore. I think this worsens over time too, perhaps the piston absorbs a small amount of oil over the years. It starts off as 'lazy' brakes but eventually they stay stuck on.
I fixed mine with a complete lever disassembly. It's not too hard to do, but it's fiddly and there are small pieces. I used this YouTube tutorial:
The main difficulty is getting the lever piston screwed back in, so I'd definitely recommend you try to find the specific tool SRAM make for this. I bodged it when I realised I had a lever in pieces and a ride planned for later that day (info on the bodge in the YouTube comments section). Sanding the piston down is easy and very effective.
My brake works like a champ now 🙂
Posted : 26/06/2020 10:19 am
It's usually the plunger in the lever. This is an issue on earlier models of Guide and I guess same with Level.
SRAM have fixed this but you need either the new model lever or get the updated service kit.
OR, DIY option is to file down the plastic plunger (videos on YouTube for this) or get the alloy replacements. It's such a common issue the Chinese have been knocking up loads of these.
Pulling apart and reassembling the lever is the main tricky bit. I don't know about Level brakes, but Guide has two types, RSC and the rest. The RSC needs a special tool to set the adjuster, although you can bodge it like I did.
Posted : 26/06/2020 10:57 am
I sanded mine down and they work fine now. Decided to keep them (Guide REs) as I think they're are great brakes now they work. Much prefer them to Shimano and Hope are 2x - 3x the cost
Posted : 26/06/2020 12:08 pm
Seems simple enough. Mine is def the heat. First thing this morning, brakes were fine. Checked at midday, lever for the rear hardly works. Moved the bike into a cold workshop, working again.
(pic from Amazon)
Posted : 26/06/2020 1:44 pm
So Sram have fixed this in later models? Anyone know when? I'd like to know if I buy a new set of REs, will they will come with the fixed lever?
Posted : 30/06/2020 3:40 pm
I believe it was a rolling change to production. Dunno if the fix worked 100%.
Posted : 30/06/2020 11:16 pm
You don't need to buy heavy metal pistons, the Taiwan plastic ones as long as labelled G2 work and fix this.
As before, I had to take a file to my circlip pliers and there was a LOT of swearing to get them out. Not convinced I wouldn't just buy new brakes next time - only did mine as they were the expensive ultimate ones and I had already invested in problemsolvers...
Posted : 01/07/2020 8:18 am
