just bought some marked (2013 -) - they are bigger than my usual ones but fit in okay
however, pad isn't making proper contact with full area of the disc - just the inside area
is this because the pad is incompatible, or maybe because disc is a bit worn?
thanks
Hope seem to have started supplying larger pads for M4 calipers, deeper than the ones they have before. I mailed Hope as I thought I'd got the wrong ones, but apparently not. So now all my disks have the same problem as you using hope pads, so I'm not using them any more which is a shame because I like them. So unless you have practically new disks this will be a problem.
Shimano M755 pads fit mono m4's too. I've found the sintered Shimano pads feel better than the Hope ones (and can usually be had for less £ too)
Superstar for me, work fine..
fergusd - I think you've got it! wonders of t'interweb.........
[quote=charliemort ]just bought some marked (2013 -) - they are bigger than my usual ones but fit in okay
thanks
can you explain that better, I'm not getting it.
pads go in caliper okay but are actually bigger than my old ones
from what fergusd said Hope have changed the design for a slightly deeper pad
this is okay if your rotor is new and nice and smooth. Mine is a bit worn so pad only engages inner bit of rotor and doesn't touch the main smnooth surface
hope that helps......
Yup that's it
