I was lucky enough to spot an in stock set of Trickstuff Direttissimas on Bike24 about 6 months ago at a time when I had some cash in my “bike pot”.
They’ve been amazingly good but I can’t help wondering if a set of Hope Tech 4 V4 might be just as good and let me put a few (hundred) pounds back into the bike pot for other things.
Has anyone ridden both and can tell me how they compare? I care about lever feel (free stroke and total stroke), overall power, quality of feel (I know this is subjective), robustness and reliability. I’m happy to spend ages getting them set up perfectly but then ideally I’d not need to constantly faff to keep them that way.
Now would be a good time to offload them as they’re still in basically perfect condition but on the other hand if I ended up regretting it then it’d be impossible to buy another set! Poor me, I know 😂
I realise this isn’t what you’re asking but it may add food to your thoughts… I’ve got tech3 levers E4 calipers on one bike with 203mm & 180mm rotors & tech4 levers and E4 calipers on the other bike with 180mm & 160mm rotors. Same red pads in each.
The tech4 even with smaller rotors have as good if not better power, but more noticeable than the power is the modulation and feel. They’re probably the best brake I’ve ever used; one of the nicest features on Hope levers is the adjustability - I’ve got little hands and struggle to get a nice feel with a lot of manufacturers but then Hopes can be tweaked to perfect for me. Definitely a step forward from Hope.
I'm only commenting as I'd like to know the answer. Having said that, there's only so many variables to play with when designing a brake system like this. It's mostly mechanical advantage at the lever and hydraulic advantage of the system.
Ultimately, how far do you move the lever and how much does that move the pads.
I think quite a bit of the trickstuff magic was reducing friction losses and I believe that the Tech 4 has tried the same. Bearings 9n the lever pivot, stainless piston sleeves, I believe there's even a bushing in the master cylinder and a lighter return spring.
Sorry, I've ridden neither but I've heard lots of people say they prefer the E4 to the V4. Not sure why. I'm curious as I'll be buying some next year.
one of the nicest features on Hope levers is the adjustability – I’ve got little hands and struggle to get a nice feel with a lot of manufacturers but then Hopes can be tweaked to perfect for me.
This is a real positive, I only have one nit with the Trickstuff and it's that I'd love there to be a bit less free stroke. If I could just wind the lever into its travel slightly like you can with the Hopes then it'd make all the difference.
I’ve heard lots of people say they prefer the E4 to the V4. Not sure why.
I'm guessing but it could be that the V4's larger calliper piston diameter causes the lever throw to increase. Perhaps those folks prefer less lever stroke between the initial bite and lock up and find the E4 to have enough absolute power such that the V4 isn't worth the trade off in lever throw?
Relatedly, my first impression (before riding) of the Trickstuff was that the lever was quite soft feeling. This was actually me misinterpreting the low system friction which makes the levers so much lighter to pull. Once I actually rode them I realised they didn't need much effort to get to the maximum usable power.
I think quite a bit of the trickstuff magic was reducing friction losses and I believe that the Tech 4 has tried the same. Bearings 9n the lever pivot, stainless piston sleeves, I believe there’s even a bushing in the master cylinder and a lighter return spring.
Right, and I think it's that stuff that gives them the hard to describe "great feel". Everything is tight, precise and light to the touch. I've read all of these words as descriptions of both sets of brakes, I'd just love to know what someone who has squeezed both thinks 😆
I’m guessing but it could be that the V4’s larger calliper piston diameter causes the lever throw to increase.
Yeah I've heard that actually. Apparently the E4 give up max power sooner which I think I'd prefer.
Let's cut to the chase...how much you selling them Direttissimas for?*
*for everyone else's benefit obviously, I can't buy them!
It wouldn't surprise me in the least if Hope got a set of Trickstuff brakes to benchmark against for the Tech 4. Question is, did they just get close, or did they actually beat them?
Apparently the E4 give up max power sooner which I think I’d prefer
And I guess you can always go up a rotor size to get the equivalent power if you want it (unless you're already on 220).
Let’s cut to the chase…how much you selling them Direttissimas for?*
*for everyone else’s benefit obviously, I can’t buy them!
Lol I was hoping to get a bit further into the thread before revealing the stealth ad! I've seen some folks asking insane prices for them but probably just look to recoup what I paid and make sure they're going to someone who plans to use them rather than sell them on. Regardless, they're not for sale yet!
It wouldn’t surprise me in the least if Hope got a set of Trickstuff brakes to benchmark against for the Tech 4. Question is, did they just get close, or did they actually beat them?
Tell you what, everyone chip in to buy me a set of Hopes and I'll do the comparison for you. It'll be worth it I promise!
Given that you actually have a set of Trickstuff, I reckon that means you and Tomhoward are about the only people who could do a comparison
Same, if anyone wants to send me a set of hopes, I’ll do a Direttissima/Maxima comparison…
(I’m actually thinking about a new set of brakes, between Hope, Radic, Braking and BSA, because niche)
So niche, I've not heard of most of them.
Pretty sure RickDraper has/had both and I'm sure I've seen a comment from mboy about the Hopes being as good as the Trickstuff. Could be wrong though 🙂
Those Braking inca's are not good looking at all. I know that's not supposed to matter but for that money I'd at least want to not hate them.
The BSAs are an acquired taste too (and I’m pretty sure there’s a link betwixt them and Braking.)
Radic KAHA look good though.
I can't even find the BSA ones. All these brakes are either impossible to Google, or have terrible websites with a lack of useful information.
Cosmetically, I'd forgive almost anything if they work well and are endlessly rebuildable.
Took some rummaging, but https://bici.andreanigroup.com/en/product-search/?cat=FRENI
For the BCA’s
No arguments from me on that one, they look great.
Embarrassingly I still haven't had time to try my V4's, I have taken the Maximas off my Megatower and replaced them with the V4's, I will hopefully get time to try them this week. One slight niggle is I wish hope would stop drilling/dimpling the brake lever where your finger sits, the smooth Trickstuff levers feel a lot nicer to hold as they aren't dimpled.
appltn
Those Braking inca’s are not good looking at all. I know that’s not supposed to matter but for that money I’d at least want to not hate them.
They look amazing in the flesh, and come in black and silver now also
It's good to see some of you are waaaay further down the rabbit hole than me when it comes to bike parts.
I've just had a weekend riding 4-pot Deores on a 180mm bike and they seem to offer all the braking I could wish for.
I've heard from people I trust that Trickstuff brakes are amazing, but how would you describe the benefits they bring in terms of the rider experience?
Paul Aston, who is very forthright in his comments on product, rates the Tech 4s as the best brake on the market right now. I'd like some in the future, though still happy with my Tech 3 E4s.
Paul Aston, who is very forthright in his comments on product, rates the Tech 4s as the best brake on the market right now. I’d like some in the future, though still happy with my Tech 3 E4s.
Hasn't/won’t try Trickstuff though, mainly because of lead time (2 years, as a regular punter buying direct), and I guess Trickstuff haven’t sent him any.
I've been doing maths to compare hydraulic ratios between the Hopes and Trickstuff based on this spreadsheet.
* Trickstuff Maxima (17mm and 16mm calliper pistons, 9mm lever piston) gives a hydraulic gain of 6.728.
* Trickstuff Direttissima (14mm and 16mm calliper pistons, 9mm lever piston) has a gain of 5.988.
* Hope Tech 4 V4 (16mm and 18mm calliper pistons, 9.5mm lever piston) has a gain of 6.430.
* Hope Tech 4 E4 (16mm and 16mm calliper pistons, 9.5mm lever piston) has a gain of 5.676.
This doesn't account for lever length which is also key to the power that a brake can output, unfortunately I can't find information on the geometry of the Tech 4 lever blade. It does at least suggest that the Hopes will be in the same ballpark as the Tricksuff equivalent in terms of power though.
I have a feeling that the Tech 4 lever might be longer than the Direttissima and possibly the Maxima which would crank up the power at the expense of more lever throw. This is a total guess though.
It’s good to see some of you are waaaay further down the rabbit hole than me when it comes to bike parts.
I'm not sure what you mean.
Hasn’t/won’t try Trickstuff though, mainly because of lead time (2 years, as a regular punter buying direct), and I guess Trickstuff haven’t sent him any.
He did review the Direttissimas a while back for Pinkbike, I'd love to know how he compares the two but it doesn't seem like he's going to tell us.
New calipers since then though.
I’m not sure what you mean.
Geeking out over fancy niche kit.
Even if they’re not quite as powerful (I have tried neither) you can actually by the Hope brakes which is more than can be said for the Trickstuff ones. I know people still awaiting theirs from ages ago.
Speaking of which, Intend - purveyors of ridiculously engineered German things, have just released this…
There’s a lot to unpack from that, but I’ve never seen those calipers before.
Mine took 10 days, and 2 years, to arrive.
Good point (I have them!) afaik they just introduced a different pad shape and easier bleed port but kept the functionality the same?
(I have them!)
I don’t. Because I ordered ‘custom’ brakes, (The res cover and lever were black, with a silver body) I didn’t get the new caliper.
Brakes are amazing, company is shit to deal with.
And that point it why I'd probably end up fitting Hope unless someone convinced my that Trickstuff were vastly better
I have to say I've had the opposite experience. I managed to shear a bleed port screw and then a lever bolt in pretty quick succession and each time I had a replacement in the post (free of charge) within a day or so of emailing. They took ages to arrive because of shipping from Germany but I can't really knock them for that.
I don't think either bolt should've sheared from the force I was putting on them but that's another issue, at least they dealt with it quickly for me.
I haven’t had to ask for any spares/assistance yet, people I know that have, it’s been good. They always responded quickly to emails, it was just the contents of the mails that have left a sour taste. Seems once you get the brakes, everything is good, it’s just getting to that stage.
@appltn - Paul Aston said recently that he thought the new Hopes were the best brakes he’s ridden. He also liked the Braking Incas 2.0 but I believe there were problems with them.
/blockquote>What I don't quite understand is:
Full set of Andreani upgrade fork cartridges with compression and rebound adjustments and springs - £500
Set of MTB brakes - £1300, rotors not included.
Surely the brakes have less parts than the cartridges?
What brakes are best is a pretty much pointless question for any brakes, they're all pretty much similar, looking at flow or pressure gains and so on is pointless as well, that's good for a closed system but disc brakes on a bike, with so many outside influences (rotors, pads, conditions, compressive rates of the fluid, etc).
Most people can adapt to any brake, given time for setup and use, i've seen more change in brakes by changing pad brands/types than changing actual brakes in terms of actual performance, i.e. ignoring the whole function part such as bite.
£1300 for a set of brakes? Blimey, and people have the cheek to moan about £150 jeans!
Aren’t they €770 a pair?
I've got the previous hope e and v on two bikes.
The v are better in the super steep stuff. I prefer the e everywhere else.
I’ve been doing maths to compare hydraulic ratios between the Hopes and Trickstuff based on this spreadsheet.
My favourite spreadsheet.
Total system leverage (hydraulic + mechanical) leaderboard:
49.8 Trickstuff Maxima
41.4 Hayes Dominion A4
39.5 Trickstuff Direttissima
38.6 Magura MT5/MT7
36.1 Formula Cura4
35.6 Hope V4 Tech3
32.7 SRAM Code
unfortunately I can’t find information on the geometry of the Tech 4 lever blade
By my rough measurement of this side by side photo, they're 85mm long from finger to pivot (30% longer than Tech3 67.5mm, which is consistent with Hope's power increase claims). This would be a mechanical leverage ratio of 7.7 if the pivot-to-cam distance is the same, for a total system ratio of 44.8 (V4). @RickDraper could perhaps measure for us?
I will measure the Tech4's tomorrow for you.
Thanks. Forgot to mention - the measurements are:
Middle of the pressing finger to blade pivot (mm)
Blade pivot to cam, Max (mm)
Lever blade is approximately 75mm from the middle of where my finger sits and the cam measures 12mm from the centre of the lever pivot to the centre of the pivot for the master cylinder plunger.
The price of those Maximas above is mental, I think mine were £1100 roughly including import duty.
I’ve paid less than that for my three sets (2 Maxima, 1 Direttissima), new, combined…
The ones that do sell S/H tend to actually sell for RRP.
Pro tip. All the big German resellers seem to have placed speculative orders some time ago, Trickstuff work on a first come first served basis, so they are fulfilling these orders as and when, so you may not have to wait all that long (still months) if you put an order in with them, rather than paying mental money S/H, or waiting 2 years going direct, assuming they let you order.
RRP feels like a fair price to me, they're still selling at a premium compared to what they might fetch if they weren't supply constrained but also the seller isn't profiteering from the scarcity (like a ticket scalper for example).
Having said that, I guess that person is free to ask whatever price they like. It isn't what I'd do but if someone pays it then I suppose there was a market after all.
38.6 Magura MT5/MT7
36.1 Formula Cura4
35.6 Hope V4 Tech3
32.7 SRAM Code
Based on these measurements the Tech4 V4 and E4 would slot into the leaderboard like this:
40.2 Hope Tech4 V4
38.6 Magura MT5/MT7
36.1 Formula Cura4
35.6 Hope Tech3 V4
35.5 Hope Tech4 E4
32.7 SRAM Code
That's pretty interesting to me as the Tech 4 V4 is pretty much at the same level as the Direttissima. Also interesting to notice that the Tech4 E4 is about equivalent to a Tech3 V4.
I just made these measurements on the Direttissima lever and got 69cm lever length (to the centre of where the finger sits) and 10.5mm from the centre of the lever pivot to the centre of the plunger pivot.
This means that the mechanical leverage of the Direttissima is 6.57 compared to 6.25 for the Tech4.
I'm getting into territory that I don't fully understand now but I think that might indicate that the Tech4 could have a lower lever throw than the Direttisima at equivalent length but it is probably about the same given that the Tech4 lever is 5mm longer.
If that's correct and given that the power output is about the same then it might be fair to say that a Tech4 V4 is very much comparable to a Direttissima.
Can anyone confirm or debunk my thinking?
I found a set of Tech4 V4 to fiddle with, squeeze and directly compare to my Direttissimas (though I didn't get to ride them). I have some conclusions:
1. The Hopes are very nice things, really well made, everything is tight and smooth. The Trickstuffs though are a cut above even the Hope quality of finish.
2. Looks wise, the Hopes are more industrial and functional looking, the Trickstuff are sleeker and more polished (literally and figuratively). The Hope V4 calliper is frigging huge. These things are subjective and a given person might prefer one or the other depending on taste.
3. Lever feel. The Hopes have a distinctly "softer" lever feel compared to the Trickstuff. They have a longer throw between bite point and fully locked and to me it gives them a slightly vague feel compared to the Direttissima. I have a feeling that the Tricksuff Maxima might feel similar in comparison given that they also have a longer lever blade.
4. Free stroke. The Hope bite point adjust allowed me to dial in the free stroke just a tiny bit shorter than I can manage on the Direttissima. We're talking about 15mm of free stroke on the Trickstuff and about 12mm on the Hope so it is just about perceivable.
Overall, I'd take the Hopes over every other set of brakes I've tried except the Trickstuff Direttissima. If I were buying a new set today I'd have trouble justifying the cost of the Trickstuff over the Hopes, but given that I already own them I would consider swapping to the Hopes to be a minor downgrade.
Again, this is just based on feel - I didn't get to ride them.
Sorry if I missed it, but did anyone try to describe (without using stats) how Trickstuff brakes give a better ride experience than mainstream 4-pot brakes?
You can brake MUCH later. Or squeeze the lever less hard, reducing arm pump.
Not really (tried Maximas & Dirretissimas).
My chosen set up of Code RSC’s on HS2 rotors is pretty solid. The Trickstuff brakes feel a bit nicer, lighter lever, bit more bite (not as much as a Saint though), mostly noticeable when doing the car park test. When on a trail, at pace, I would struggle to define them as a ‘better’ riding experience due to all the other noise/activity going on.
I didn’t go any quicker with them, noticeably brake any later, or have a better riding experience because of the brake & I’d challenge whether people really do. Like a lot of high end kit, are people really buying it for that extra 0.5% performance or are they buying it because its niche, expensive & blingy?
Which I have no issue with at all, I have some fancy bits because I liked the look of them too. Are the EEwings on one of my bikes any better than the XTR’s on the other? Absolutely not in reality.
A few things to mention having owned some Trickstuff Maxima's, and owned or ridden most of the other brakes mentioned in this thread...
The Maxima's are absolutely amazing, but the price exemplifies the law of diminishing returns, even when picked up 2nd hand for 20% below rrp... The Maxima is simply a case of applying marginal gains theory to every single component part of the brake... The master cylinder is stiffer than anything else out there, the lever runs on two cartridge bearings, everything is machined to exacting tolerances, they use 6mm braided hoses (makes it a MASSIVE pain in the arse for internal routing on any bike, big part of the reason I sold mine) rather than 5 for a bit more fluid volume, the leverage ratio is larger than any other similar brake on the market which should make them really spongy but the tolerances they're built to mean they're not spongy they just have fantastic modulation that really has an effect on feel at the tyre and the lever. They really are brilliant... But...
Ignoring the price, there's a few issues... Not least of all actually getting hold of a set, or any spares. Then there's the reality they won't crash well compared to many other brakes. The 6mm hoses mentioned above don't fit in many/most hose guides and for internal routing it may involve you having to physically enlarge the ports on your frame! The modulation is exceptional, but realistically, the extra power they deliver over the best of the rest is wasted... I found a 200/180 combo too much, even at over 90kg and on a Geometron being ridden pretty hard I had power in reserve. I even fitted some cheapo crap pads to them to tame the power down a bit! They're a bit of a faff to bleed too, albeit if you follow Trickstuff's video exactly then you will get a decent bleed on them in the end.
I haven't had any time on Tech4's yet due to not being able to ride for months, but have had a play with them a couple of times... Also spoke to the Hope tech guys at EWS Innerleithen about them and had a play with them on Joe Barnes' bike there too. Simply put, the Tech3's had FAR too much friction in the system, something which Hope had come to realise (and obviously brakes like Trickstuff had shown them what could be achieved if cost no object)... The Tech4 lever as I understand it, was designed to significantly reduce the friction in the braking system, thus leading to much less effort required at the lever for the same level of power. They also reduced the master cylinder size slightly for more leverage. Basically, following Trickstuff then... No bad thing! The Tech4 as a result seems to deliver more power and better modulation for less effort. Win/win!
Obviously that's not the whole story though... The Hopes don't have much if any progression to their action. We know brakes like the high end SRAM Codes and most Shimano brakes have a swing-link or some kind of a cam action, to increase the leverage as the lever goes through its travel... And whilst the Trickstuff's don't have this, the lever design means they do have a lot of progression built into the feel (so a regressive rate) simply because of the angle between the lever pivot point and the master cylinder being quite open, increasing leverage relative to finger effort as the lever goes through its travel... Think of a single pivot bike with a falling rate, like an old school Santa Cruz Heckler... The thought of a regressive rate on a suspension system these days sends shivers down my spine, but on a brake system the opposite is true, as you want the system to deliver more power for smaller additional lever inputs as the lever goes through its travel.
Anyway...
What's the answer...?
Well I can't disagree with HobNob here I'm afraid... As amazing as Trickstuff brakes are (and even the new Hope Tech4's), brakes don't make you go faster... Subjectively you might have a nicer riding experience, possibly a bit less hand fatigue (which can be a worthwhile reason of course for many people), but when it comes to going quickly, smooth is best... And to coin the old Pirelli phrase of "power is nothing without control", when it comes to brakes, modulation and control are far more important than outright power if we want to ride smoothly and hence quickly...
With this in mind, you simply can't beat SRAM Code RSC's I don't think... If you want more power, fit a higher friction pad or step up to a 220mm front rotor now they're available. The modulation and control on offer from SRAM's brakes still bests anything else IMO, and for most of us the power on offer from the Code RSC's is enough in reality. Replacement parts also relatively easy to get hold of and won't brake the bank if you do crash them either...
You can't brake much later at all... The limitation in the system is always the amount of grip from the tyre. Just like you can't brake much later on a road bike with disc brakes compared with rim brakes... What you can do is benefit from better modulation and less hand fatigue potentially. But if you can physically lock the tyre up with an existing brake in the conditions you are riding in, you simply cannot brake much later!
FWIW I have hardly ridden MTB in the last 2 years for various reasons, mostly health. Spent a lot more time on motorbikes, mostly fitted with Brembo setups of different capability. You can have too much power... Or rather you can have too little modulation on a system that'll easily overwhelm the amount of grip available from the tyre! Modulation and feel is everything... The fastest riders in the world aren't going fast cos they're able to brake later than anybody else then square off the apex of the corner... They're the fastest motorbike riders because they can feel EXACTLY the amount of grip they have, balance the braking/cornering forces with incredible accuracy through feel afforded to them by great tyres, a brilliant chassis setup and wonderfully well modulated brakes. The ability for Marquez to trail brake at over 60deg lean on his bike and feel everything that's happening to the point where when he does lockup he can do it so gently that many times he has even picked himself up from a slide (I don't recommend doing this BTW, he is a bit unhinged and incredibly skilful!) is nothing to do with the amount of power available from the brake, but everything to do with the amount of modulation and feel it affords him.
Also, working for a tyre company, you'd expect that I understand the limitations of your only two contact points with the ground, and the forces acting on them to try to overcome their ability to do their job effectively, better than most... 😉
Not sure if its been mentioned - some long long posts here, but maybe note that trickstuff are two piece calipers bolted together, and i wonder if that system makes for less flex in the caliper.
Hope calipers only have a small bit of metal holding the 'two' sections together, while trickstuff that area is reinforced by a steel bolt. The steel bolt is stronger than just plain alloy and i think gives the section more rigidity.
Not sure if its been mentioned – some long long posts here, but maybe note that trickstuff are two piece calipers bolted together, and i wonder if that system makes for less flex in the caliper.
That goes against conventional thinking though, and the main point why a few brake manufacturers still persist with monobloc calipers is they assert they can make a stiffer caliper from a single block of aluminium...
That said... I'm sure someone at Trickstuff did their FEA homework making sure the Maxima calipers were stiff enough even as a 2 piece design...
Nope,monoblock (ie machined from a single piece of aluminium) calipers are known to be far stiffer than two halves bolted together in all forms of Motorsport,so therefore i assume thats true for bicycle brakes.
Monoblock calipers are harder and presumably more expensive to make than two halves.
Having said that im sure you could make a flexy monoblock caliper if it was designed poorly
Might be more a reflection of the brakes I was running immediately prior (Various shimano, Guides), but if I braked at the same spot I’d be going noticeably slower through the following corner. Generally I’m braking a couple of bike lengths later I reckon, harder & for less time.
Went from G2 RSC to Hayes Dominion A4, so similar ballpark i.e. markedly more powerful than Code RSCs etc. Finger pain on long descents or long days gone. Brake later and harder. Confidence for less speed management or comfort braking. Definite performance benefit but perhaps also a bit in the mind.
As a practical example, before these I would be backing off and taking breaks for my hands/fingers between trails by the time I was halfway down the Glentress black.
So I had problems, tried all sorts of things (brake lever angle, bar roll, finger exercises). Already on 200/180 rotors. I'm not a heavy rider nor am I particularly fast, I might just have weak fingers. Mainstream e.g. Codes might have solved it but they're not that much more powerful on paper (32.7 vs. 30.5 total leverage) so I thought might as well go all-out for a top-line brake (41.4) for confidence that it would solve it first time.
Also, working for a tyre company, you’d expect that I understand the limitations of your only two contact points with the ground, and the forces acting on them to try to overcome their ability to do their job effectively, better than most… 😉
I'm trying to figure out why*, but I always felt that the faster you go the less the wheels lock up? So in a straight line you slam the brakes on as hard as you like, and start to slow down, untill you slow down to a speed where the wheels lock up.
*Possibly something to do with if deceleration is linear then the majority of the work is done in the early part but the change in momentum is linear, or if the work rate is linear then the change in momentum (and therefore acceleration) will be a square relation to the time?
Not read this thread but just seen the price of a chain in the STW shop advertised in the right hand panel ---> over there. £63!! for a Chain!! WTF!!
I know right?! Bargain!
£63 chains are pretty much mid range now, much like £6k mtbs are.
https://www.sjscycles.co.uk/chains/kmc-x12-dlc-12-speed-chain-blackgreen-126-links/
https://www.sjscycles.co.uk/chains/kmc-x12-dlc-12-speed-chain-blackgreen-126-links//a >
That’s just got bad taste / anodising addiction tax added.
I have experience of 3 sets of brakes. Not quite apples with apples, but anyway:
Trickstuff Piccola
Trickstuff C21 calipers on Red AXS levers.
Hope Tech 4 V4
Trickstuff
The most amazing quality and tolerances, resulting in really powerful brakes for their weight. In terms of engineering, performance and finishing they are just beautiful and the manufacturing and finishing are unmatched anywhere. BUT they are totally proprietary and finding spares and maintaining them is difficult given the lack of support and leadtimes. And the availability makes them virtually unicorn s##t to actually find. The availability and price almost makes them unviable in the real world. The weight of Trickstuff is really only worth the price if you have shaved literally every other gramme off you and your bike (and who can truly say that?)
Hope
Nowhere near the same quality as Trickstuff, but definitely the next best thing, and given availability and pricing it is hard to argue against them. I am using 2.3mm 200/220 rotors and the V4 calipers and the stopping power is nothing short of phenomenal.
In my experience, the trade off of size and thickness of rotor makes a bigger difference than brand. The enemy here is less pure hydraulic power and more battling heat and fade and the geometrical advantage afforded by bigger, thicker rotors. Put bigger, thicker rotors on most brakes and they perform better.
In summary, Trickstuff are good, but the availability, price and lack of support make them all-but impossible to recommend. Hope have amazing support, are affordable, available and provide more than enough stopping power. The V4 with thicker rotors have proven to be worth the weight penalty for me. Has anybody ever wished for less stopping power?!
It's been a while since this thread was updated. I was wondering if any of those with Trickstuff brakes had managed to get time on the Hope tech 4 since their last comments.
I might have the Trickstuff Maxima as an option i'm a bike I considering. 3 option really, 1. Ignore and fit Hope, 2, spec and use Maxima, 3, order with Maxima and pass on to someone else.
Atherton?
Last?
Anyway, taking out the issues of getting hold of Trickstuff, I’d say the Maxima just edges the T4V4. The lever feels a bit nicer, and there’s a bit more initial bite. There’s really not a lot in it though, to the point where personal preference will say which is ‘Best’
Worth noting that even if you use the Maximas, you’re likely to get what you paid for them if you move them on later.
I had a brief dalliance with a set of Tech4 V4s a few months ago which ended with me returning them (reminder that I'm on Trickstuff Direttissimas) you can read the process of slowly coming to this decision from here onwards in the Hope brake thread.
The short version is that they're probably very nice, but I had issues with a set that were leaking fluid (as have a few other people) and ultimately decided that even once I got them sorted out they weren't going to be better than what I already owned.
If I didn't already own the Trickstuff I'd probably consider the Hopes more carefully, but overall I agree with @tomhoward that Trickstuff definitely edge out the Hopes. Whether that's worth the extra cost is questionable and depends on the person squeezing them.
Cheers chaps. Feels like tomhoward is somewhat aware of my current musings.
I've been keeping up with the Hope thread and as a self confessed Hope fanboi, I'm surprised at how long it's taking them to get on top of current issues.
As the Trickstuff would come as part of a build, they don't seem to be massively more expensive than Hope. However, being in the UK, it's much easier to sort leaking hope brakes than it would be leaking Trickstuff.
Watch out for my next thread asking about what to do in Dortmund...
38.6 Magura MT5/MT7
36.1 Formula Cura4
35.6 Hope V4 Tech3
32.7 SRAM Code
Where do Shimano 4 pots fall in this list. On the fabled spread sheet there are two values, 28.971 (average for vari cam) and 39.835 (Peak)
Haha. I should just come to you directly for a build consultation
Anyone? Are they worse than SRAM or better than Trickstuff?
system leverage is not the only factor. Pad area needs to be considered as well. Even then its still more complex
You're not wrong, but that's not what is being compared here.
This seems like a good place to ask this.
It’s time to upgrade the brakes on my Kenevo. I’m a big bloke on a big bike, I need big brakes. The Code R on it doesn’t cut it.
I live in Australia, so the maths is a big different on options thanks to shipping prices and distances.
I’ve done far too much research, and STW seems like the place that appreciates the options I’m considering.
The options I’m tossing up are:
- Trickstuff Maxima - I found a set in stock, no rotors but I can get Intend rotors locally. Expensive but I won’t be wanting for more power and regretting taking up the option.
- Radic Kaha - since they’re made in NZ, easy shipping and relatively fast for spares etc. Cheaper than a Maxima setup by ~AU$500. From reviews, sounds like they may be a little more light switch like than the Maximas.
- Hayes Dominion A4 - believe it or not it’s been easier to find a full Trickstuff setup in stock than front/rear Dominions and rotors. Seems like they’re 95% of the Maximas for 60-70% of the money if I can scour the internet for suitable 220/223 rotors.
Hope makes no sense for me. They work out the same price or a bit more than the Kahas thanks to exchange rates and shipping.
Does anyone have any feedback on all three, or just want to validate my Maxima purchase? 😂
