Carrera Luna Build ...
[Closed] Carrera Luna Build 24"
9 Users
After seeing how small my daughters Isla bike has started looking I thought I had better get around to finishing the Carrera Luna I bought for her.
I'm really pleased with how its turned out.
The original bike was bought for £20 from gumtree with the intention of throwing most of the parts in the bin.
I started collecting parts as and when I saw them and had parts in my spares collection. Total spent is around £130 minus my existing parts. I haven't weighed it but its really quite light and could lose a bit more with better wheels. In honesty the original wheels are not as bad as I expected but the original tyres weighed a tonne. I was planning on changing the wheels but I doubt Ill bother.
My daughter chose the colours and I got it chemically dipped then sprayed it fluorescent yellow with a silver glitter lacquer on top.
I may look at increasing the forks to 80mm so I can run them a bit softer and still get some travel. At the moment to get them soft enough to move the pressure is so low they are not fully extended. I may also set the wheels up tubeless for a bit of puncture protection.
[url= https://farm2.staticflickr.com/1830/41997611285_f4c1673e31_k.jp g" target="_blank">https://farm2.staticflickr.com/1830/41997611285_f4c1673e31_k.jp g"/> [/img][/url][url= https://flic.kr/p/26ZbJEi ]IMG_5424[/url] by [url= https://www.flickr.com/photos/155059150@N07/ ]Andrew Downing[/url], on Flickr
Full Spec
Frame: Carrera Luna 24"
Forks: Fox F120. Spaced down to 60mm.
Headset: Original Carrera
Wheels: Original Carrera (de-stickered)
Tyres: Schwalbe Rocket Ron
Handle Bars: Race Face Next SL Carbon
Stem: Race Face Turbine
Grips: Santacruz Palmdale
pedals: DMR V6
Crank: Suntour XCT JR 150mm (original rings thrown away)
Chainring: Raceface Narrow Wide 32t
Bottom bracket: Shimano Un71
Rear Mech: Shimano XTR 9speed
Rear Shifter: Shimano XT
Cassette: Shimano XT with bottom but one cog removed.
Brakes: Sram Elixr
Brake Rotors: original Carrera
Saddle Post: Orange
Saddle: WTB Devo Carbon
Saddle Clamp: M-part 31.8mm Slim
Posted : 19/06/2018 1:59 pm
Nice work.
My lad has outgrown his 24" Blast which I rebuilt - this is now being up-cycled for my 7y/o daughter.
Posted : 19/06/2018 2:13 pm
Nice build mate and at a good price too.👍
Posted : 19/06/2018 2:31 pm
Posted : 19/06/2018 2:32 pm
Thanks
I think the tyres were the most expensive part at £37 for the pair.
Posted : 19/06/2018 3:59 pm
Nice! I'm currently building a Blast and Luna for my twins, your spares box must be a bit more substantial than mine!
Is the crankset factory white?
Posted : 19/06/2018 8:16 pm
Thats nice that. Keep meaning to gwt my lads blast powder coated but never seem to get round to it....
Posted : 19/06/2018 8:33 pm
Nice
Posted : 19/06/2018 8:34 pm
The cranks come in white or black in various sizes.
I got mine from an eBay shop and rang up before buying and the owner checked that the rings were removable and the bolt holes are a standard bcd. Some of the cheaper cranks I looked at had riveted rings that were made to look like hex bolts and wouldn’t of worked.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F152487439243
Posted : 19/06/2018 8:59 pm
That's a pretty shiny build.  In a few weeks time I'm getting a delivery via my parents of a knackered Blast for my daughter so will be doing the same again.  I take it the standard rear hub is 8-speed sized?
Posted : 20/06/2018 4:09 pm
The standard rear hub has a 7 speed freehub which is not as long as an 8/9/10 speed freehub, hence the OP having to fit the cassette minus one the sprockets.
I would consider that after the brakes, shifter/drivetrain and tyres the next upgrade should be the wheels because the standard rims are rubbish.
Posted : 20/06/2018 4:20 pm
It's worth noting that SRAM do their NX crankset in 155mm arms, which is perfect for kids. It can be a little tricky to get hold of and it's a bit more expensive (less so, if you take into account the 32t N/W chainring that they already come with), but it is a proper 1x crankset which uses a more modern GXP BB rather than a traditional square-taper (you may consider this good or bad depending on your opinion on such things!).
Nice build!
Posted : 20/06/2018 4:26 pm
Erm, yeah, I meant 7.  Think I'll strip my wheel down and rebuild it around a spare hub.
Posted : 20/06/2018 5:20 pm
