WTF !!! mega car ty...
[Closed] WTF !!! mega car tyre wear.. whats caused this. ??
53 Users
I've just seen this on one of my car tyres and started to feel a little bit sick.......
[URL= http://i2.photobucket.com/albums/y33/renton1/IMAG0364_zpspcftocvz.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMAG0364_zpspcftocvz.jp g"/> [/IMG][/URL]
We only bought the car at the start of the year and the tyres were fine. We have done less than 6000 miles.
WTF has caused this then ?
The other side is the same but not worn through.
There is no play or knocking etc in the suspension. This was the front right tyre.
Posted : 24/07/2015 4:43 pm
Assuming that is the inner edge it'll be the toe settings. The wheels are either splayed apart or pointing ino each other.
Posted : 24/07/2015 4:45 pm
Being a tight git and spending out on wrong size tyres.
hmmmm, I spot a reoccurring theme here. lol
Posted : 24/07/2015 4:46 pm
Excessive toe out or excess negative camber, broken springs, worn bushes/ ball joints, tracking incorrectly set
Posted : 24/07/2015 4:48 pm
 br
Show your local tyre dealer, ask for advice while getting the wheel alignment checked/adjusted.
Posted : 24/07/2015 4:50 pm
Hopeychondriact wtf are you actually on about ??? It's no laughing matter.
We had similar, although not as bad as that, caused by a combination of toe in out of alignment and lots of those square sleeping policemen things where we lived.
Posted : 24/07/2015 4:51 pm
Stance?
Posted : 24/07/2015 5:05 pm
Poor cornering technique.
(I always park my car at home with the wheels turned so I get a look at the tyres each morning. Sad I know, but ^ that's why.)
It's a family estate car not a rally car ?
Posted : 24/07/2015 5:07 pm
It was a joke, should have put a smiley I suppose. Good job you spotted it in time!
Posted : 24/07/2015 5:09 pm
Not stanced at all ......
[URL= http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0182_zpsg57njdnv.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0182_zpsg57njdnv.jp g"/> [/IMG][/URL]
Posted : 24/07/2015 5:10 pm
Deliberately doesn't mention cornering/29ers/other threads....Oh.wait
Sorry the great ape.
I'm waiting for hopey nobbby up there to come back and explain his crap post.
I've had my family in the car with that on. I'm not finding it funny.
Posted : 24/07/2015 5:11 pm
No worries. I used to drive a Mondeo police car, and when you booted it there was quite a bit of torque steer. I'm not an engineer but I wonder if that could cause it?
Posted : 24/07/2015 5:14 pm
Massive assumption from one pic, but if it goes up and down kerbs, that may gradually nudge your alignment out (although it's much more likely to be one or more big knocks, judging by how bad yours looks) - previous owner?
Posted : 24/07/2015 5:15 pm
Fadda... It's put up the kerb by using the dropped kerb behind the car and always reversed off the same bit.
Previous owner used it mostly on the motorway. ?
It's weird as it doesn't pull all over the road etc.
Posted : 24/07/2015 5:18 pm
 cp
that's really gone through right round the shoulder - something is properly wrong with your suspension set up.
I had something very similar happen to a VW Jetta when a damper was shot. Guess the wheel was just bouncing up and down all the time. Weird you've got it on both fronts though.
Take it somewhere proper to get looked at.
Posted : 24/07/2015 5:19 pm
Ah, it's a mondy estate. My smax (same car essentially) had similar wear after about 10k from new (I got it at 2.5k). First set of tyres wore in the same way. Was toeing out, hence my guess. Not sure if it's a ford wear in thing with the suspension.
Posted : 24/07/2015 5:21 pm
i've had my family in the car with that on. I'm not finding it funny.
Surely if you were that bothered by their safety you'd check the tyres regularly, they haven't got like that over night
Posted : 24/07/2015 5:25 pm
Mondeo estate? Mine did that. Both sides. Getting the tracking done seemed to sort it out iirc.
Posted : 24/07/2015 5:29 pm
Had a golf that didthat was the camber that kept the car on the road.
Had it set neutral once. Had it put back within 3 days, car handled like crap,
Just lived with the wear over 40k.
Have yours looked at by a pro somethings not right with that- as said your right round the shoulder surely you would have noticedthe tracking out tht far- unless you never driven a straight car before !
I did have an escort do something similar actually - id not seen the speedbump as you leave nevis range after a long days downhilling 4 up and 4 bikes on so no suspensipn travel left.... Bent both wish bones badly,
Posted : 24/07/2015 5:30 pm
Low pressure in tyre , so tyre moves out on cornering, always use an independant gauge to test pressures not the garage pump.
oh and its a fine and points for driving on a tyre with exposed thread, and dont rub hand along the thread, youll get speared by rusty metal that will go septic in a few days, i did and it did.
Swop tyres, front left to rear right and likewise to even out tyre rub and wear.
Posted : 24/07/2015 5:31 pm
He's right, I did, and I was.
Posted : 24/07/2015 5:35 pm
 kcal
if they were fine 6k ago then something's not right as above.
Plenty of honest and good garages about town too -- give Wisharts a call. Sandy's Reids pretty good too.
Posted : 24/07/2015 5:36 pm
Maybe it's the fact you're driving it on pavements that is leading to excessive wear. 🙄
Posted : 24/07/2015 5:59 pm
Alignment I reckon, the previous Mondeo to yours was known to go out of alignment with relative ease.
Posted : 24/07/2015 6:05 pm
It will just be the tracking.......do you have lots of 'witches tits' sleeping policeman in your area? If you do I would suggest no more than 10-15mph over them but good technique by hitting them with both wheels at the same point, because if you do t it ends up knackering wishbones and tracking! My wife can confirm theses salient points 😆
Posted : 24/07/2015 6:07 pm
Had similar on my car but on rear and not quite as extreme but having everything realigned resolved it.
Posted : 24/07/2015 6:11 pm
Were they, or have you only now just had cause to look at the inside edge? When I got my first car I checked the tread depth religiously and still managed to drive around for (presumably) months on a tyre with the steel poking out of the inner edge. I only spotted it when I happened to park with my wheels at a rakish angle one day.
But yeah. As others have said it's probably something toe / tracking / wheel alignment related, get it checked.
sleeping policeman
I drove the hatch version of that Mondeo (Titanium?) "briskly" over speed bumps for four years and never saw anything like that kind of wear pattern. I'd respectfully suggest it's not that.
Posted : 24/07/2015 6:13 pm
Yep toe in / tracking problem. Shows nicely that you should occasionally put your wheels on full lock to check the overall conditions of the tyres. That would be worth a big fine plus points if you were caught by the police.
Posted : 24/07/2015 6:18 pm
Sorry but it was, not talking about normal sleeping policemen, but the square ones that you try to straddle.
Posted : 24/07/2015 6:20 pm
Renton I think [u]hopeychondriact[/u] is confusing you with Molgrips?
Posted : 24/07/2015 6:21 pm
Nope the tyres were fine as I checked them as if they were i was going to barter with the garage to change them.
I check the tyre pressures weekly and also they are fitted with pressure monitors.
I understand that I should of checked them and feel sick thinking about it as I've had my family in the car. Thanks for rubbing it in though.
How on earth does driving up a dropped kerb cause wear like that then hopeychondriact you are coming across as an even bigger knob.
Posted : 24/07/2015 6:22 pm
Mrovershoot I hope that is the case as if not it's pretty poor skills.
Stu170 thanks for the kind words. I dont think that at all.
Posted : 24/07/2015 6:23 pm
When we were quite a bit younger we noticed a mates tyres were down to the wire when he had sparks coming from the underside of his car.
Posted : 24/07/2015 6:27 pm
No worries renton. Struggling to work out whether you are after pity? How you don't notice that is unbelievable
Posted : 24/07/2015 6:43 pm
Is that the inside or outside of the tyre?
Just that one or others too?
Posted : 24/07/2015 6:46 pm
What RD said...
Posted : 24/07/2015 6:50 pm
It's both the front tyres on the inside.
Posted : 24/07/2015 6:56 pm
 hora
Ok, I'd have your alignment/tracking checked but also your suspension/arms etc. No point doing one fix and its actually a combo.
Tbh I dont check my tyres- only before big journeys.
Longshot- you dont drive up kerbs to park regularly? The previous owner of my first Forester did (as he demonstrated on the testdrive where he said he parked it every night outside his house- it led to the driveshaft failing.
Dont dwell on feeling sick. You've caught it and your sorting it.
'What ifs' existing every day. Its how we remedy that matters.
Posted : 24/07/2015 6:59 pm
Did you just turn up looking for a fight?
Look on the bright side, you didn't get pulled over then use that attitude with the police to talk your way out of a sizable fine. I believe it's now up to about 2500 quid and three points per tyre.
When you bought the car, chances are the wear had already started in that vein , but it probably wasn't that noticable when you run your hand over it or kicked the tyre. If it's even on both sides, it's most likely the alignment or the suspension. Judging by the photo, the tread on the rest of the tyres says that you were about due a new set regardless.
Posted : 24/07/2015 7:13 pm
This >>>>
Posted : 24/07/2015 7:24 pm
I used to be a chassis engineer at an oem. Get the geometry check by a proper outfit with a proper 4 wheel alignment machine, a hunter or similar. It's probably toe out or too much negative camber (caused by wear or damage as I don't think it's adjustable ) or both. My volvo was doing it when I first got it and it was just toe
Posted : 24/07/2015 7:25 pm
Not just the fine but if you did have an accident and somebody died they could just try to pin it on you and go for manslaughter. And that includes a member of your own family - remember the Land Rover bodger who drowned a couple of his own kids? Tragic.
Posted : 24/07/2015 7:26 pm
 hora
Agree those tyres were very low across the whole tyre- those are your traction/steering/grip wheels too renton. You should have noticed that walking towards your car. As I said I dont do a regular physical check but a glance as you approach would be obvious. Sorry.
Posted : 24/07/2015 7:32 pm
its a combination of things in my experience
Modern high power high torque diesels and ever heavier cars knock tyres out much quicker. 10-12k is about normal life expectancy now
Id say its toeing out though which might be the default geo
Posted : 24/07/2015 7:34 pm
I got 20k out of my last set.
Posted : 24/07/2015 7:35 pm
Not sure where you are but I've had wheel alignment checked and adjusted at CLCM in Edinburgh. The guy that runs it seems decent and sorted issues with my Alfa as the tyre wear was very uneven. He told me the number of brand new cars that come out of the factory with issues is crazy. I would stick some new tyres on and get the thing checked.
Posted : 24/07/2015 9:26 pm
Are those OEM wheels?
Wrong off/inset?
Wheels/tyres touching some part of body?
MrGrim - Member
Used to work on Fords in the '70s, similar problems then! Capris and Cortinas in particular 🙄
Posted : 24/07/2015 9:27 pm
Standard wheels for the model of car it is. No signs of rubbing.
Apart from the one area of massive wear the rest of the tyre has worn pretty evenly.
I've not come here for a fight at all. But some of the replies I'm getting are bordering on downright abusive.
Yes I know I should of checked them more. I'm quite aware I'm in the wrong.
Posted : 24/07/2015 9:49 pm
I've got a set of winter and summer tyres. It's surprising how well running the different tyre types at the right time of the year has been contributed to tyre wear. 33k now and two set of only very partially worn sets of tyres.
Posted : 24/07/2015 9:50 pm
 Euro
Following on from Tonyg and his 'any old tyre story', my dad was the last guy to leave when the Mallusk Michelin factory closed. He got his giant, pale blue baldy head on the news and everything.
Posted : 24/07/2015 10:01 pm
I think it's a ford thing ....lots of fords have this problem. .A bit over ambitious on the toe out...Prob to improve handling... feel more stable ...just get it checked I had mine taken in a few degrees and are fine now
Posted : 24/07/2015 10:09 pm
I've just had a similar issue with mine. Inner wear, one side only. I'm usually pretty attentive but missed this. I managed to get over 30k miles from the front Conti Sport Contacts on my D5 V70 despite the damage. They had a bit left in them but the shoulder damage meant a change. Same again for me. I was getting ~18k from Bridgestone's on my A6's.
Posted : 24/07/2015 10:13 pm
 myti
Such judgemental people on here! We lead busy lives, mistakes happen but you lot judging never ever make any of course! Nothing more to add sorry.
Posted : 24/07/2015 10:14 pm
OP - I had similar wear on our family car (Mazda) 1600 miles after some work was carried out on the front suspension. Happily we spotted it before it got to the state yours is in, but surprised you didn't notice wheel vibration and a certain amount of "pull".
I think it's toe-out that's wrong so look that up. If you want to take it further then 2 pieces of advice: retain the tyres if you get them swapped and, get the "before" alignment readings when you get the tracking done.
If it's got a service record you might want to see where any work was done and what was carried out too.
Finally, ignore those who choose to be tossers on here. I asked for some help and got some A1 advice together with some less than helpful.
Posted : 24/07/2015 10:37 pm
A few degrees? 😯
Posted : 24/07/2015 11:28 pm
I had a pair of tyres worse than that, one right through on the inside. I got pulled over for a random check and I had to leave the car as they considered it too much of a risk to drive. I knew they were low approx 6 days before this happened and I couldn't believe how quick one went through to the wire. The car had been sitting there and I was using another vehicle, on my day off I chose to use the car with dodgy tyres as it had a full tank of fuel and unluckily passed a patrol car about 11pm. Very unlucky but I chose to drive it. £200 fine for each tyre and 3 points.
I'd remove the wheel and put the spare on for the trip to the garage. Points for speeding is fair enough but it's a mare getting them when you've not gone over the limit all day! Even if your excuse is 'I'm going there right now', you're still driving on a dodgy tyre.
Posted : 24/07/2015 11:40 pm
Ive an 08 Mondeo estate and it did the same on the first set in 12mths. 4 wheel alignment done and new tyres and that had resolved it in the 2 years since.
I hit/ straddle square speed bumps all the time (not to mention pot hole galore). Not made a difference,all good since tracking done.
Posted : 25/07/2015 7:23 am
All done. 2 new tyres and 4 wheel Hunter alignment. £298.
Here is the alignment printout....[URL= http://i2.photobucket.com/albums/y33/renton1/IMAG0365_zpsuj2fcqbm.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMAG0365_zpsuj2fcqbm.jp g"/> [/IMG][/URL]
Apparently the all four wheels were pointing outwards.
Posted : 25/07/2015 8:56 am
I had similar renton, 2003 Mondeo estate, my problems were at the back, trashed a set of rear tyres in 6000 miles and very nervous handling, normal garage said nothing wrong.
Got the alignment done and it was like a different car. We had it a couple of years before selling and I think the alignment was on its way out again by that point.
I'm now of the opinion that tracking, laser tracking, laser alignment and all the other terms your average tyre fitter uses to big up their crude front tracking check is a complete waste of time, especially when they can't even get the wheel centred before making adjustments!
Proper 4 wheel alignment on a Hunter machine or equivalent is money well spent if you have unusual tyre wear or the handling doesn't seem right...the problems at the rear of both Rentons and my Mondeo wouldn't have been detected by a tracking check.
Posted : 25/07/2015 9:34 am
I had exactly this on my mondeo, worn drop links caused it.
Car felt absolutely fine, but after i had the drop links replaced the car felt better (less body roll) and the excessive wear was gone.
I cant remember how much it cost exactly, but it wasnt that expensive.
Posted : 25/07/2015 10:11 am
Was that front or rear drop links ?
Posted : 25/07/2015 10:17 am
There's probably some truth in this. I worked out once, my old Mondeo was costing me about 10p/mile just in rubber.
Posted : 25/07/2015 10:23 am
Had this on my Mondeo due to mistake by alignment tech using the wrong settings.
My new tyres were shredded after 3 months.
4 new tyres and alignment - the tyres were great for another 20k.
Hope your car is sorted and keep an eye on tyre pressures too.
Posted : 25/07/2015 10:48 am
renton, just the fronts, but a couple of years later the rears wore out as well, same result, excessive tyre wear.
car still felt fine, but was definitely better when fixed.
230 notes a pair, fitted, at an independent garage, my wife reckons.
no other symptoms.
EDIT: in response to duncancallum, yeah, mine was a turbodiesel too.
Posted : 25/07/2015 1:22 pm
Christ! How are some people driving!
I have excepting punctures been getting c20k - 22k out of a pair of tyres! That's on 2x 3.0 TDI four wheel drive cars so torque is pretty high. I am using premium branded hi- spec tyres. No different to to my previous high bhp four wheel drive petrol hatch.
Posted : 25/07/2015 2:07 pm
 hora
Ive only changed tyres (2) once in 10yrs.
The car normally goes first 😀
I never wheelspin though
Posted : 25/07/2015 2:14 pm
You make up in frames though 😉
Posted : 25/07/2015 2:27 pm
 irc
Wow! 32K on my petrol Octavia and only looking to change the OEM tyres now. Around 2mm on the front. 4mm on the back. Even wear over the tyres.
Posted : 25/07/2015 8:24 pm
Poor tire life out of modern high power diesels is a factor of driver.
Goes fast in a straight line must go fast round corners.
Heavy breaking to scrub the load pedal over use
Also poor clutch control.
2 sets of tires in last 90k for me.
Posted : 25/07/2015 9:30 pm
Power steering and a heavy block isn't great for tyre wear either.
Posted : 25/07/2015 11:44 pm
Incorrect use of power steering to dry steer and a heavy block isn't great for tyre wear either.
FTFY 😉
Gone through 3 sets of tyres in 110k here. First set of Intensa Savas lasted 12k and got scrubbed to nothing, cheap rubbish and bad tracking were their demise. Next got a set of Maxxis MA-P1's which lasted from 65k to about 90k interspersed with a set of Hankook Icept EVO's which lasted to 140k. Now on Hankook Ecosomethings which look as if they're doing okay.
Just a 1.7l block mind but I'm not exactly gentle if I'm honest. Religious about dry steering though, there's absolutely no excuse unless you're turning an HGV trailer.
Posted : 26/07/2015 12:34 am
I would seriously look at the history of the car as it could be a cut and shut, bent chassis or just badly repaired.
Contact previous owner! 🙄
Posted : 26/07/2015 4:58 pm
Or just needed a simple adjustment?
Posted : 26/07/2015 6:50 pm
So how does it drive after the tweaks?
Posted : 28/07/2015 4:08 pm
Is it hells bells.
As an aside - energy saving tyres, the ones with scilica in like your Conti black chilli mtb tyres last at least twice as long as normal tyres as well as saving a bit of fuel. I reckon you save more money on the cost of replacing them than you do with fuel.
The Michelins on the Prius lasted 60k miles, the Nokians on the Passat (big heavy diesel) have done about 50k - the fronts have about 1.5mm on and the rears are barely half gone. Only problem is a broken spring has sawtoothed the insides, so I'm going to change then anyway.
Posted : 28/07/2015 4:29 pm
Wish I'd read this thread before I had a front tyre blow out on Friday.
FWIW I knew my treads were getting low but still easily legal.
But stupidly I hadn't turned the wheels so I could inspect the inside edge of the tyres. Which weren't!
My tracking was out so that edge was considerably more worn and blew on me at about 65mph in the outside lane.
Lesson learned there.
Pricey emergency visit to KwikFit - but better than the alternative outcome!
Posted : 28/07/2015 4:35 pm
