Wordpress problem -...
[Closed] Wordpress problem - can't select database
3 Users
I've done all the steps recommended by WP 5 min easy install, but can't do the last, where I connect to the database and install WP to then start blogging.
Is there anything that I'm doing wrong?
Posted : 28/04/2015 12:27 pm
Have you created the database, either on you're PC or if it's hosted, on your server space? From what I can remember you need to amend a file with the db name and password that you created and it will create all the tables it needs.
Posted : 28/04/2015 1:18 pm
there is the wp-config.php file in the root of the wordpress installation that has the username, db name and dbserver name.
Posted : 28/04/2015 1:31 pm
