14 Users
so i have a design for some stickers created in word (ok so nothing elaborate) but need to convert to hi res or .jg
how does one go about this, sorry for being a numpty
Posted : 24/09/2010 10:22 pm
use the 'print screen' button. Paste into any image software, trim the pic then save as jpeg
Posted : 24/09/2010 10:28 pm
make as big as possible and screen capture, then crop and expect it to be shit quality
then do it again with proper software
Best way (if using OpenOffice) is to save as PDF then open in Photoshop or similar.
But never, ever, Trevor, design in Word. It is shit.
Posted : 24/09/2010 10:31 pm
I believe the correct response is "[i]post it on here and we'll give you some advice"[/i]. Of course, this is no more than a ruse, designed for you to provide cannon-fodder to the STW graphic designer wannabees.
Posted : 24/09/2010 10:34 pm
print to PDF with CutePDF or similar might come out better
Posted : 24/09/2010 11:04 pm
Print to pdf then save as a jpg using adobe acrobat standard
Posted : 24/09/2010 11:35 pm
Print but select document image instead of your printer and save as Tiff for better quality etc.
Posted : 24/09/2010 11:59 pm
 cp
What Frankenstein said - you'll loose quality going the PDF route- which compresses image, and then saving as a jpeg from that looses more...
Posted : 25/09/2010 6:59 am
TIFF is fine as long as the res is high enough. The benefit of PDF is that it is a vector based format and therefore is not limited to a specific resolution (assuming the Word doc does not just have a big old BMP pasted in it!)
Posted : 25/09/2010 7:28 am
 nbt
He's made the design in word. it'll be a BMP. Word is writing, not drawing. Echo the above about doing it again in proper software, there are LOADS of free image editors out there so why choose to use a word processor for editing images?
Posted : 25/09/2010 8:03 am
Alt-printscreen will screengrab the current window.
Paste into paint or, better yet, grab paint.net off the interwebs. Crop to taste.
Posted : 25/09/2010 10:25 am
nbt - Member
With all due respect, you're incorrect. Word will output postscript (vector data), when printing its built in shapes and text tools. It's only output as a bitmap if there is a photograph or similar pasted in.
Posted : 25/09/2010 12:28 pm
No arguing chaps, image editing software? I can only just turn the computer on!
Posted : 25/09/2010 3:02 pm
[i]image editing software?[/i]
e.g. photoshop. other packages are available; the simplest is Paint, but it really is simple
Posted : 25/09/2010 5:07 pm
 nbt
retro83 - Member
Fair enough, happy to be corrected as I didn't know that. I use word for word processing, I use photoshop for image editing
[b]rOcKeTdOg[/b], think in bike terms. You wouldn't use a hammer instead of a spanner: You wouldn't buy and Intense M6 to use solely for commuting: you don't use word for making pictures. Irfanview is free and well recommend it - google it, install it, learn to use it.
Posted : 25/09/2010 5:32 pm
I haven't edited pictures for years now but using office to type reports.
So whats the easiest to use and is better than paint?
Photoshop? I'll have to get myself a copy and start weaving!
Also when printing to image (not printer) via word and you can save the file using bitmap, jpeg or Tiff etc so you have plenty of options.
I think office 2010 has more editing options which I need to get a personal copy soon!
Posted : 25/09/2010 6:02 pm
STW graphic [i]designers[/i] in being snobs shocker!
With all due respect nbt, if its been done in Word, its more likely to be vector-based and as such if you are going to recommend a [i]better more professional programme[/i], then it would probably be something like Illustrator, Corel Draw, Freehand or (free) Inkspace.
But TBH if Word can do what RD wants then what is the problem?
Posted : 25/09/2010 6:05 pm
If you don't have pdf writer, the use Windows mdi (Microsoft document imagining) printer and set output to .tiff should be an option in your word printer options, though in later xp and win 7 it is hidden - you will have to look up on the web on how to unaided.
Posted : 25/09/2010 8:10 pm
As above, Paint.NET. http://www.getpaint.net/
It reminds me of what Paint Shop Pro used to be like before it started taking itself too seriously.
Posted : 25/09/2010 11:52 pm
so i downloaded inkspace and was able to paste the word image into it, looked fine in hi res, saved it as a jpeg and forwarded it to the printer, waiting to hear back if it was good enough
cheers all
Posted : 27/09/2010 8:49 am
so word to jpg via Gil@thecycleshed produces this
[url= http://farm5.static.flickr.com/4087/5040081814_f008ae1a50.jp g" target="_blank">http://farm5.static.flickr.com/4087/5040081814_f008ae1a50.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5040081814/ ]365-274[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
Posted : 30/09/2010 8:37 pm
