Woodburnerunderfloo...
[Closed] Woodburnerunderfloorheattrackworld
4 Users
Putting the feelers out. I know nothing re plumbing but was asked by a friend if it's possible to have a solid fuel range with a back-burner (connected to water mains) to provide rads or under-floor heating yet *without* a water-tank?
Fag-packety sketch. Any advice much appreciated!
*edit - rightwayup 😳
Posted : 05/11/2017 1:06 pm
Wont work straight off the mains, youd need a vented (or unvented but not for DIY) circuit around the boiler and the rads/UFH. Also worth having a load charger on the heating circuit.
http://www.stovesonline.co.uk/heat-chargers.html
Posted : 05/11/2017 1:17 pm
Woah thnks Stoner - have passed that info on much appreciated 🙂
Posted : 05/11/2017 1:41 pm
the back boiler has to be sealed [ open or closed] and not inked to the mains - you can use say an immersion tank and circulate from there or just use a header tanks and pump the water round the [ system - this has to be closed and I used an open system.
For underfloor you will need a pump as I would be surprised if open gravity fed works for that [ though you could do gravity fed to the tank and pump from there - though this would take ages to heat up.
Posted : 05/11/2017 1:50 pm
 Bear
I assume that Stoner has linked to some kind of accumulator or thermal store.
thermal store would be the easiest as you could have a hot water coil in it and also add other fuel sources should you want.
Remember when siting a thermal store that it will make that area very warm and in well insulated houses it can be a problem as it needs to be hot all year round.
Posted : 05/11/2017 2:00 pm
