wood burner install...
[Closed] wood burner installation advice.....can i?
6 Users
OK we live in a 13 year old house with the standard flue built into the cavity for a gas fire.
Can i get an adaptor so i can use the flue as the exhaust for a 4kw wood burner, or would i have to have an external flue fitted?
Posted : 07/10/2012 7:44 pm
Hi, I fitted a multifuel stove in feb of this year in my house(65 years old) then a friend asked me to fit one into his 15 year old house and we used an external flue.
Posted : 07/10/2012 7:56 pm
 br
First thing, get someone to check your flue.
We thought we'd do the same at our last house, newish house with a fireplace and flue - guy took one look up and said, No. Apparently it might be a hole but its certainly not a flue...
Posted : 07/10/2012 8:34 pm
 Bear
Class 1 flue only! If it was just for a gas fire itll just be a bog standard copex which ain't good enough. Do you have a fireplace and is there a chimney up in t roof?
Posted : 07/10/2012 9:31 pm
as above .. you need a class 1 flue ( what that looks like is a brick built chimney on the inside, if when looking up its made of cast concrete blocks or you can see a steel corrugated liner its NOT class 1)
Posted : 07/10/2012 9:34 pm
 Bear
According to part j you can use flue blocks.
Posted : 07/10/2012 9:42 pm
Yes you can use flue blocks or standard 225 clay liners but they obviously need to be in place now!
Posted : 08/10/2012 11:57 am
