Looking for a new router for the house, so whats good and reasonably
priced for basic wireless internet connection?
Replacing a six year old Belkin G which is now decidedly shonky!
Cheers G.
I'm happy with my Linksys WAG160N.
Netgear DGN1000 would be my recommendation!
I also have a Linksys/Cisco WAG160N, which has a 300Mbs speed, was incredibly easy to set up and has a handy network map and connection repair feature.
I have 10 pieces of equipment that run via the router in some description or another. It does drop out occassionally, but I'm usually re-connected in seconds, rather than the 5+ minutes it used to take my old Thomson router supplied by Tiscali.
Linksys, Belkin or Netgear are all good. Was your G rouer ok, or do you need to extend your range?
If you dont just go for a G router, although you can get Netgear DGN1000 from about £35 if you look around.
Range on the G was fine covered the house garden etc. It just drops constantly and takes an age to reconnect(if at all!).
I have an Amazon voucher kicking about so will check out any recommedations there.
Quick check says the Linskys not compatable with talk talk?
Strange that gamo, as I'm sat here using Talk Talk (was previously Tiscali, but they got bought out/changed name, whatever). Unless it's something to do with still being on the original Tiscali server and there's a different one for original Talk Talk users????
I would keep away from Belkin personally, I have had nothing but trouble.
Linksys/Cisco is always my first choice.
Beware Netgear N routers (check models carefully)
We had a DGN2000 and the ethernet ports packed up. Apparently this is a common fault, linked to the design being prone to overheating
Currently trying a Billion, but too early to tell. Easy set up and good signal strength, just hope it lasts longer than the Netgear.
Linksys, Netgear... to be honest, most home Internet routers are much of a muchness these days, so long as you stick to a known brand and avoid the bottom-feeders you shouldn't go far wrong.
draytek 2820 but might be a bit over the top for your requirements
I've got a Billion 7300n,which replaced a Belkin that dropped out and needed rebooting,or resetting at least once a day,the Billion runs a lot cooler and after 3 months has been much more reliable,with better signal strength.
Ian
anjs - Memberdraytek 2820 but might be a bit over the top for your requirements
For most small offices they are OTT.
Hmm i've heard a few of reports of DGN2000's dying.
If your wireless was working fine and has now gone shoddy, a neighbour may be running on the same channel as your WiFi.
Download [url= http://www.netstumbler.com/downloads/ ]Netstumbler[/url] and run it on your laptop to see what channels neighbours are running and change channel accordingly.
Had an unbreakable Dlink (506T I think) for about 4 years until last summer. Replaced it with a Netgear DG834G and it's been a POS the last few weeks; connection (wireless and wired) drops virtually every day and has to be rebooted multiple times.
Not impressed - which is contrary to 95% of reviews you'll find.
<goes off in search of guarantee>
I got one of [url= http://www.expertreviews.co.uk/wireless-routers/279061/tp-link-td-w8950nd ]these[/url] from Amazon - £25 and working flawlessly so far.
I found that if the DGN1000/2000's have a problem with the ethernet ports they can be set to fixed Ip's. Could be a design floor but Netgear's customer service is great so will always go with them.
