Wireless router que...
[Closed] Wireless router question
7 Users
Got a new D-Link wireless router....all working fine for internet access except I can't login to it in order to manually change settings.
I can get the login page up using a web browser but the default login details don't work. I've done a factory reset and used admin/admin as suggested but in doesn't recognise them. I set the thing up using the CD and changed the PW to "admin". Still no luck.
Any ideas?
Posted : 07/03/2013 12:18 am
 dh
maybe try a blank password or another browser.
Posted : 07/03/2013 12:31 am
Try another browser and try checking with D-Link via their support system to make sure that the documented details are correct. They may have released a new firmware or similar with updated credentials.
What model router is it?
Posted : 07/03/2013 1:01 am
admin for username, and blank password sounds familiar (binned my old d-link, so can't verify).
might need to make sure cookies are enabled too.
Posted : 07/03/2013 1:10 am
You're definitely on you router and not next door's, yes? Ie, you switch it off, you can't get to the login screen?
Admin / blank is common for dLinks. Where are you getting admin / admin from? Have you RTFM / checked on stickers under the router?
Try wired rather than wireless?
Posted : 07/03/2013 2:36 am
it's a dsl-2740R
yes - i'm def connecting to the internet via my own router both via wifi and cable from a desk top
sticker on the bottom of it says admin/admin for login deatils. I have also tried admin/[blank]
There is a firmware update but I can't install it as you need to login to the router to do this.
I've put a request in to their support but not heard back yet.
will try another browser when I get home tonight. Like I say, I can access the internet with it and the wireless is really good all around the house, just that i don't like not being able to access it to change settings.
One other interesting point: the previous router was always visible under "my network places", but this is not the case with the new d-link, which is only visible sometimes. This has no baring on interrnet performance or ability to login to the router.
Posted : 07/03/2013 7:32 am
are you running noscript or something similar in your browser - I seem to remember that causing me some headscratching
Posted : 07/03/2013 8:01 am
Sorry, I'm a bit of an IT nupmty...how would I find out if the above is the case. I'm using IE on XP.
Posted : 07/03/2013 8:15 am
I'm using IE
Then I think you're not using script blockers (they're sort of anti-malware - bit of a PITA to be honest. You'd know if you had it as lots of sites wouldn't work until you allowed java/flash to run on them)
Posted : 07/03/2013 8:19 am
AV could be interfering too, potentially.
Are you sure it's "admin" and not "Admin"?
Posted : 07/03/2013 10:01 am
admin
password
http://answers.yahoo.com/question/index?qid=20090429175713AAx74nC
Posted : 07/03/2013 10:07 am
I've tried Admin/admin/password in vaious combinations.
Cheers for all the suggestions folks, will try all that tonight and report back.
Posted : 07/03/2013 10:40 am
Following advice gratefully received, I can now access the router settings using the default UN and PW.
Solution to the problem was to clear history, cookies and temp internet files from IE. The router will now let me login without problems.
Thanks for your help!
Posted : 07/03/2013 8:40 pm
glad it worked.
funny some people appreiate free advice here and yet others scorn if the correct answer isn't the time frame of 30mins
http://singletrackmag.com/forum/topic/vv-ot-importing-antique-ammunition-to-the-uk
Posted : 07/03/2013 9:34 pm
