Wireless network wo...
[Closed] Wireless network works fine but cant connect to router with CAT5
12 Users
I have a netgear router that has worked perfectly as a wireless router for several years. I now need to add a smart DVD player and SKY box via power plugs. If I turn the wireless off and connect it directly to the router with a CAT5 cable I thought it should automatically connect to the internet etc. Am I wrong.
Please point me in the right direction.
I have a decent computer knowledge but I am by no means an IT professional.
Posted : 31/10/2013 11:05 am
Does the cable work for sure? Have you picked up a crossover instead of a straight through cable? (Are the wires in the same order at each end?)
Posted : 31/10/2013 11:07 am
If I turn the wireless off and connect [b]it[/b] directly to the router with a CAT5 cable I thought it should automatically connect to the internet etc
Turn the wireless off on what? What is the 'it' in that sentence?
You shouldn't have to turn anything on or off, you should just plug the cable into the router and into the other device and the two should connect.
If not, then as above, does the cable work?
Posted : 31/10/2013 11:10 am
I am trying to connect the Laptop directly to the router with a brand new CAT5 cable, have tried 2 new cables with no difference.
I am turning the wireless on the laptop off so that I can be sure that any connection to the router is via the CAT5 cable as the wireless works perfectly on about 8 different devices.
I have also tried all 4 of the CAT5 connections on the router with no joy. Could it be the router is broken.
Posted : 31/10/2013 11:16 am
You'll need to give a little thought to how you are giving out addresses for each unit - each on needing a unique address.
DHCP is very common, and easy to use, your router *should* be set up to give out an address with this to each device that requests one, the downside being that the same device may end up having different addresses over time.
A static address would be better for specific devices like a DVD player/sky box, but you will need to ensure that they are given an address outside of the range used by DHCP *or* that in DHCP you reserve a specific address in the range for each device.
What is the address of your router, what DHCP range is it offering to clients ? What happens when you connect the DVD player to the router directly via a cat5 cable - does it get an ip address ? What is shown under "attached devices" on your router when the DVD player is connected directly ?
Posted : 31/10/2013 11:21 am
when the two are connected by cable can you access the router?
It should be accessible by typing something like 192.168.0.1 into the address bar.
Or open a command prompt (start->run: "CMD") and then type ipconfig and press enter.
You should get something like "ethernet adapter local area connection:"
with some words and numbers below it.
One of the lines should contain "IP Address.....123.123.12.134"
If you get that then the laptop is working and the cable is working, and the issue is likely ot be at the router end of things.
Have you gone through 'help and support'? Looked at network connections in control panel? (assuming you're on windows)
Posted : 31/10/2013 11:23 am
[list][*]Is your Ethernet connection enabled in the OS on your laptop?
[*]Is the Ethernet connection on your laptop set for DHCP or Static addressing?
[*]Does the router support DHCP? If so is it enabled? If so is it limited to a small number of addresses?
[*]If the laptop is set for Static Addressing, does the address being used match the range being given out by the DHCP Server on the router?[/list]
Posted : 31/10/2013 11:27 am
Is the laptop set to obtain the ip address automatically on the LAN connection? It's possible it's set to a specific IP for that connection.
Posted : 31/10/2013 11:28 am
Just to set the record straight as no ones answering your question 😉 .. yes it should just plug in and start working. I find it very hard to believe even a quite old router shouldn't be set to do this automatically.
Take a look at bails post above, there should be an IP address noted on the router along side the Wifi name/password (not necessarily the one he's posted), that when plugged in directly will allow you to access the router configuration via a browser window... even if you have no interent connection via it at the time, it should connect you to the admin login. Do that and look for the DHCP setting.. see if they are enabled.
Posted : 31/10/2013 11:33 am
Netgear 834GT?
mine recently failed in exactly same mode, ADSL modem + wifi fine, ethernet ports dead.
Posted : 31/10/2013 11:46 am
DHCP is activated, I can log into the router through HTTP://192.168.0.1 through a wirelessly connected laptop but not through a laptop connected directly to the router with a CAT5 cable. does this help to diagnose the Ethernet ports as being dead.
Posted : 31/10/2013 12:02 pm
It could still be the config of the ethernet port on your laptop.
What OS are you running?
Posted : 31/10/2013 12:06 pm
sounds like it. I tried several different laptops to connect, a range of cables and even flashed the firmware.
binned it and bought a cheap ADSL modem and an apple airport express to manage wifi.
Posted : 31/10/2013 12:07 pm
Any lights on corresponding to where you've plugged the ethernet cable in on the router?
Also make sure your ethernet adaptor is enabled on the PC. Got to networking in control panel, view network adaptors and make sure there is not red cross on the one you're trying to use. If there is, right click and select enable.
If its enabled, try updating the driver too.
 kcal
Ethernet port not enabled in laptop device manager?
Is there a lamp above the ports on the router, does the lamp illuminate when the cable is connected?
Is the laptop the only PC device in the house - i.e. can you cross refer by trying another machine with CAT5 port?
Posted : 31/10/2013 12:08 pm
Running windows 7 on both of the laptops I have tried.
The corresponding number on the router 1 - 4 illuminates with a flashing led as if transmitting data when you connect the CAT5 cable to it.
Ethernet port is running fine with updated drivers etc.
Posted : 31/10/2013 12:13 pm
Kinda unusualy to be able to log into via wireless, as usually it's a security feature that you can only log in directly, to stop it being hacked remotely. Do as the posts above suggest (checking laptop port is enabled), then look at resetting the router to factory default? Though make sure any configuation (adsl login details specifically) have been noted & if still fubar'd, try the firmware update?
Posted : 31/10/2013 12:15 pm
Try the following:-
Control Panel > Network & Sharing Centre
Change adaptor settings
Right click on the ethernet adaptor, select properties.
Then select "Internet Protocol Version 4 (TCP/IPv4) and click properties
If its set to "use the following IP address" and there is an IP adress, subnet mask and default gateway specified, change it to "obtain an IP address automatically".
Does that work now?
Posted : 31/10/2013 12:27 pm
bigyinn, did all that but it was already set to get IP Address automatically.
Posted : 31/10/2013 12:41 pm
Turn wireless on, connect to the wifi.
Then plug in the cable.
Wait a minute.
Then go into the router control panel and try to find 'attached devices'. Is the laptop showing as a wired connection?
Posted : 31/10/2013 12:46 pm
What heppens if you run ipconfig on the command prompt connected through a cable? Does it list a "default gateway" under the appropriate adaptor?
If it doesn't, then the laptop cant "see" the router.
Posted : 31/10/2013 12:50 pm
what net gear router is it? have you run it stood upright or flat? Ive had 2 netgear routers pack up wired. its a well known issue that they get too hot and the board gives up. it still works wirelessly fine
Posted : 31/10/2013 12:57 pm
It is a DG834G and it has been run for the last couple of years horizontal and does seem top get pretty hot.
I am leading towards the router being broken.
Posted : 31/10/2013 1:00 pm
DGN1000's are notorious for doing that.
Posted : 31/10/2013 1:26 pm
Any recommendations for a new router ADSL just normal house use, couple of laptops, couple of phone connections and hopefully DVD player streaming via power plugs. Rarely is much being used at the same time.
Posted : 31/10/2013 1:40 pm
The DG834G has been around for quite some time. It might be worth trying to update the firmware before binning it.
If not I can recommend the DGN2200. Good wireless range and similar user interface, so will be familiar to you.
Posted : 31/10/2013 2:10 pm
bigyinn, thanks for all your help the firmware was a few issues out of date but updating it hasn't sorted anything so I will try and pick up a new router.
Posted : 31/10/2013 2:45 pm
 kcal
Only just ditched my DG834G this year after 9 years 🙂
Got another Netgear, updated version. Wireless-N 300, can't fault it really. Was £49, the original 834 was £122.42 !!
Mine tends to be screwed to the wall, vertically.
Posted : 31/10/2013 3:42 pm
BigSurfer - I've got a spare 834G I'm happy to sell - then you could simply backup your existing settings and restore them to the new one in less than 5 mins.
Make me an offer.
Posted : 31/10/2013 4:14 pm
Thanks everyone for all your help. Bought a new netgear router and computer connects through cat and blue ray player connects through power plugs.
Posted : 31/10/2013 7:38 pm
