Wire Rope Grips - H...
[Closed] Wire Rope Grips - Help Please
9 Users
Long shot but ....
Using some wire rope grips as part of a treehouse project and am struggling to find torque values for clamping
Grips are 6mm stainless to DIN 741 -
Vendor is closed today so I cant call ;-( and want to get building
Torque advice appreciated
Posted : 28/10/2017 8:44 am
Tighten until they strip, then back off 1/8th turn.
Posted : 28/10/2017 8:45 am
Can't help directly with the torque values. However I've used these a lot offshore. Much more important than the outright torque is that they're installed facing the correct way. Have a look at the [url= http://www.fdlake.com/wrclips.html ]Crosby Website[/url] for more info.
I'd put a Molly Hogan at the end of the rope then put the wire rope clips over the whole lot. You'll probably have to look that one up but it makes a very secure connection. Banned in industrial use years ago, but a good way of putting an eye in the end of a wire when you're short of the correct hardware.
D.
Posted : 28/10/2017 8:55 am
Thanks guys - already seen the info about correct facing and spacing so have the covered Davesport
Cheekyboy - Ta - info i have found says 3.5 N so same range thanks
Brant - lol
Posted : 28/10/2017 9:08 am
Showing your age mate! 😀
Posted : 28/10/2017 9:18 am
Out of interest, what's the alternative?
Posted : 28/10/2017 9:23 am
For what? just domestic stuff at home?
You can splice, not as hard as it looks, depending on the size of wire.
The other option is to use ferrules and a set of crimps.
[url= http://wireropeshop.co.uk/wire-store/index.php?main_page=index&cPath=1_65_206&zenid=057086861656c9960d79eca86734172e ]http://wireropeshop.co.uk/wire-store/index.php?main_page=index&cPath=1_65_206&zenid=057086861656c9960d79eca86734172e[/url]
Posted : 28/10/2017 9:30 am
I'm no Spring Chicken 😆
Thanks, no application in mind, just curious.
Posted : 28/10/2017 9:33 am
If you using them with Pelican Hooks as well, then you have done well to live that long!
Posted : 28/10/2017 9:35 am
As tight as we can when making an end stop on the tractor winch, plus an extra sacrificial one to get mashed by the sliders.
Posted : 28/10/2017 11:13 am
How come ? Wire rope grips /Crosby clamps still widely used to day offshore.
Posted : 28/10/2017 11:16 am
Everything I use is going subsea. It's all pre-made with thimbles and swages, load tested with certification and periodic inspections/paper trail.
The advent of the risk assessment did away with most ad-hoc rigging.
Posted : 28/10/2017 1:51 pm
For load bearing?
I have seen them to tidy stuff up but not for a lifting or pulling operation?
Posted : 28/10/2017 3:14 pm
wire rope slings for pipe bundles when wineracks /rhino racks are not used.
not so much north sea but ROW.
Posted : 28/10/2017 4:06 pm
Or just use Gripples
[url= https://www.bishopliftingequipment.co.uk/lashing-rigging-hardware/wire-rope-grips/gripple-self-locking-wire-rope-grip-2mm-6mm/ ]Gripple wire clamps[/url]
Posted : 29/10/2017 9:55 am
