Winterising a class...
[Closed] Winterising a classic motorbike
12 Users
I have inherited a 1978 Honda GL 1000. What should I get organised to look after it over winter. All that chrome is not going out in the winter.
Posted : 26/08/2015 9:08 pm
Oohhhh ... a nice Gold Wing. I like. 😀
You should post some pics on this thread.
Posted : 26/08/2015 9:11 pm
Taken a few years ago when my dad and I went to Aberystwyth for the weekend.
Posted : 26/08/2015 9:14 pm
Ya, that's very nice indeed. 😀
Posted : 26/08/2015 9:23 pm
ACF50 is your friend. Warm it up before applying to get a nice fine spray.
Posted : 26/08/2015 10:44 pm
Pretty sure some guys at work vacupack their bikes, not sure if they put something on the chrome first though.
Anyone any tips on stopping fuel going off and gumming up the carbs.
Posted : 27/08/2015 6:50 am
Put a trickle charger on it, start it up every couple of weeks, nice clean dry garage. Unless you want to go to ridiculous lengths that and the ACF 50
How much chrome 😯
Posted : 27/08/2015 7:11 am
drain the carbs.
or start it every week and let it tickover until its warmed up.
worked on my gt380 😀
Posted : 27/08/2015 7:29 am
I have known people to cover them with sheets to allow them to breath. Tasty bike, I always liked the look of them. Salt is the killer.
Posted : 27/08/2015 7:39 am
By drain the carbs, which I remember my dad saying he did, do you just turn the fuel tap off and run till it stops or is it more tricky than that? And then whats the process for starting again? Anyone use fuel stabiliser?
Posted : 27/08/2015 7:41 am
If you're not going to ride it simply give it a good clean with WD40 and some rags. And keep it dry
Take the battery out and charge it every couple of weeks. Obv don't start the bike unless you're going to ride it
Lift the wheels off the ground or at least reposition the bike from time-to-time
With the fuel you can either drain the tank and the float bowls or use lawnmower fuel stabiliser
Posted : 27/08/2015 7:51 am
I was thinking of keeping the tank full to prevent condensation?
How do I drain float bowls?
Posted : 27/08/2015 7:56 am
There's usually a drain plug on the float bowls
There's so much ethanol in modern fuel that filling the tank arguably makes things worse but tbh I've never had a problem with it
Posted : 27/08/2015 8:02 am
i usually started mine about once a week, run til its hot then turn off fuel tap and let it run til it stopped.
didnt know anything about fuel stabiliser, that sounds great.
Posted : 27/08/2015 8:15 am
Change all the oils before you hibernate the beast - absolutely never do the startup every now and then - this is the worst equivalent of the short trip - fills the engine and exhausts with corrosive condensation.
Brake fluid is worth changing if you can - stops the water in it corroding
specific areas because it is never moving.
Remove the battery and store it somewhere dry where you can give it a charge once a month.
Clean and wax polish the bike before storage - chrome can have some extra
protection acf or similar - decent cover for the bike essential - not plastic.
Pump the tyres up and make sure its on the centre stand .
Fuel wise I would either drain all including carbs or fill up with premium
and run bike with tap off to drain carbs.
Edit - its water cooled - refresh the antifreeze if its old - definitely check its not just water in there.
Posted : 27/08/2015 8:16 am
Fuel these days isn't the factor it once was 20 years ago. A lot of people get stuck in the past about how things were in their day. These days fuel isn't going to go 'off' in the 4 months over winter.
Posted : 27/08/2015 8:18 am
Good advice from finishthat.
I would only add that I used to get both wheels off the ground.
Rear can be supported by your centre stand, the front can be supported by any of the dedicated stands for removing the front wheel.
Regards
Denis
Posted : 27/08/2015 8:43 am
Thats been done last week. Rad had to be removed to change the timing belts.
Hmmn, thats not what I have read and been told, although I will discuss with a tame mechanic. Most of the online stuff about these old goldwings is US based so maybe the petrol mix is different over there. Most recommend STABIL additive and keeping the tank full but carbs empty. Thanks for the adice every one.
Posted : 27/08/2015 9:34 am
Also would I be better keeping the battery in the house and charging once a month or connecting it to an optimate type thing?
Posted : 27/08/2015 9:48 am
Regarding fuel.I drain the tank & run the bike until the float bowls have drained,everything I've read advises draining the tank as modern fuel additives attract water & cause the tank to rust,plus the idle jets get bunged up with residue from the old fuel.
As stated above don't start the bike as that creates lots of condensation.
Posted : 27/08/2015 9:56 am
RE- the battery - I would pop it in the house and charge ad-hoc - keep in small plastic crate to avoid acid spills.
Permanent connection to charger - not really - not for months - more of a safety thing really especially if there is any condensation risk.
Regarding the fuel - the stabilisers are definitely worth using.
For bikes that never get used in the rain the ethanol issue is less serious - apart from the melting rubber fuel pipes - the real issue is with bikes that get used in the wet - fuel fillers and vents can allow damp/water into tank - combines with ethanol in dead areas of the tank and rusts out the bottom/seams. possibly not an issue with the GoldWing as the tanks is under the seat.
Sounds like you are on top of the beast with changing belts etc.
Possibly add fork oil to the list if its not done.
Posted : 27/08/2015 10:05 am
Up to you.
Have owned sportsbikes where the battery is no bigger than a wallet and hidden under a pile of electronics in which case it's just easier to take the battery out and keep it in the house
Other bikes I've charged in situ. Batteries discharge at a slower rate when they're cold I find a boost every couple of weeks or so is fine
Gold Wing tanks are plastic are they not 😕
Posted : 27/08/2015 10:08 am
I paid a professional!! I am a mechanical numpty. I dont mind changing oil or brake fluid but I wouldnt want to get timing belts wrong!!
Prett sure mine has a metal tank, modern ones might be plastic
Posted : 27/08/2015 10:21 am
