Where has the auto run option gone when using a memory card?
Step father is struggling with his camera card, the least amount of steps to copy the contents is required.
Can anybody help
Control Panel\Hardware and Sound\AutoPlay
Should be what you need
Settings, devices, Autoplay.
Should list all the things you've connected, with a drop down list of options.
Edit: this is for Windows 10
it's there and slightly even more annoying, has he disabled it, when the options 1st came up?
http://www.howtogeek.com/236241/how-to-enable-disable-and-customize-autoplay-in-windows-10/
Auto play is selected but still not opening
Is this not still a security risk?
W10 will pop up a notification when you insert a memory card asking you how you wish to import photos. If you don't catch the pop up the action should be in the action(notification) centre
My wife uses Picasa so that comes up as one of the options. The default will prob be photo
