Picture this. We have our sky router in the living room of the house - this is plugged into an Apple Airport Extreme which takes care of the wifi.
I need to get a stronger internet connection into the gym which is at the bottom of the garden - about 25 metres away from the Sky router/Airport Extreme.
I have an Airport Express half way between which is set to extend network as well as airplay, but it's still really hit and miss in the gym.
Different power circuit so Powerline adaptors out.
I want to start using Apple TV or Amazon Fire TV in the gym to stream video content from Beachbody on demand...
So. Am I best somehow strengthening the wifi (we don't get great speeds here anyway, and the Airport Express doesn't seem to do the job.)...or do I run a cable out the side of the house, down the fence and into the gym? We have spare outputs on the router, and I'm sure I could make a neatish job of it...it's a bit of a hassle though.
(Just checked speed, it says 38ms Ping, DL 7.8Mbps, UL 0.34Mbps)
If I use cable, at that distance does it make a difference which cable I use? Is the connection bit any different on Cat 6 to Cat 5?
Thanks for any help
Powerline adapters work fine on different circuits ime. Certainly an easy thing to try.
Really? shows how much I know. How does it connect then?
Will look into it, thanks
Is running an Ethernet cable out of the question? You could bury it shallow down the side of a path/boarder/flowered.
Cheapest most reliable solution and you'll get full speed too.
You can run Ethernet cables up to 100 meters before you have to worry about it.
^ I could do that, but which cable? Is it Cat 5/6/7/8/9? Does it matter?
It's all bewildering.
I'd go for cat5 e.. STP (shielded twisted pair)
Good for 100 meters.
You could get cat 6 but it's more expensive and probably wouldn't benefit you at all.
I'd run armoured CAT5. It's not as if you need it for safety reasons but I can guarantee that you'll forget that it's there, and you'll kick yourself when you put a spade through it... Been there done that etc.
Not prohibitively expensive either.
try the powerlines, it may work.. it worked between my house and garage which have different consumer boxes.. but i got pissed off and ran a proper cable in the end.. cat 5e.. gigabit switch at each end.
run wired where you can.
Yeah a cable with a more robust sheeth could be an option or run it through some plastic trunking in danger areas ..
That said though cat5 is cheape to replace..I probably wouldn't bother.
Also you don't need expensive branded cable..Just a generic one..cat5 is a standard so if it meets the standard it's just as good as the belkin ones that cost 5x more.
Thanks all, I'll get shopping, drilling and digging.
Cat 5, run it through some re-inforced garden hose for a cheap way of giving it some protection.
As others have said, full speed and no fuss. If you want WiFi in the gym, just bung another airport in on the end of the cable
Cat 5 is the best option IMO, had power-line adapters in my workshop that was on a separate circuit to the usual ring main and it was flaky most of the time.
20 meters of Cat 5e and its solid as a rock.
Went overhead as I had concreted in the 6mm SWA last year so didn't want to dig that up.
I have some external CAT6 cable on a reel that I used for the run to my garage. But then you need terminal tools to fit the ends. If buying premade cables then you need to make some big holes in the wall if you need to feed the connectors through. Much easier to thread through the naked ends and then terminate them in situ.
If you want cable and a few ends then I am happy to send/sell at cost+postage. You would need to buy your own £10 crimp tool.
Make sure any cables you buy are full copper and not something called CCA (copper clad alu).
I'm lazy..id probably buy a premade cable that's plenty long enough, drill a bigger hole for the plugs to get through..then once im happy everything's ok, put a bit of expanding foam in the gap.
