Which aerial booste...
[Closed] Which aerial booster?
4 Users
I want to try and run 2 or 3 tv's off the one aerial using a booster to try and bump up the signal. I've checked and we've got a high gain aerial, thought it was a medium.
Are boosters pretty much the same or any of them recommended?
Thanks
Posted : 10/01/2012 4:16 pm
 ton
wolsey 4 way signal amp is our biggest selling.
£12.10 + vat and a fiver for deliver.
Posted : 10/01/2012 4:20 pm
Ok Ton cheers, can I paypal you the amount then?
Posted : 10/01/2012 6:41 pm
Run 4 TVs off one antenna without an amp no problem here. Old house had a naff antenna and I used a £4 aldi booster, worked perfectly.
Posted : 10/01/2012 6:57 pm
 ton
granny_ring - Member
give me a ring if you want one.
01132633500
Posted : 11/01/2012 8:54 am
We bought a [url= http://www.tvaerials.com/product.aspx?productid=422 ]ProCeption StarBox[/url]. Has loads of features, power for masthead amp, can cope with Sky/Cable/CCTV/FM/DAB too. Great quality too.
Posted : 11/01/2012 8:58 am
Will be in touch Ton if I want one thanks for your help.
Posted : 12/01/2012 2:25 pm
