Whey protein...what...
[Closed] Whey protein...what do you know ?
8 Users
Just a body builders tool or of use for someone who mixes his training between the bike, the gym, and running ?
Posted : 18/12/2012 12:01 am
When I was doing a bit on the bike, I swore by it for aiding recovery. Used to use the plain stuff from myprotein.co.uk
Try it - what's the worst that'll happen?
Posted : 18/12/2012 12:20 am
Bulk up..I don't want to bulk...will it ?
Posted : 18/12/2012 12:22 am
Anyone ?
Posted : 18/12/2012 9:16 am
You'll be fine. It's just for recovery, not getting guns.
Posted : 18/12/2012 9:18 am
Again, i use it now and again if i am training alot but only for recovery. You will not bulk up using it, thats specific to the type of training you are doing. Not protein shakes.
Posted : 18/12/2012 9:21 am
I use it as a recovery aid. Started with the 25% protein 75% carb stuff that is often recommended for recovery, but it was a bit at odds with trying to loose weight. Now just use plain whey protein with (almost) no fat and low ish carb content. I don't use daily though, maybe 2-3 times per week? I make it with water, not milk, to keep the cals low
I'd say I've trimmed up, not bulked up
Posted : 18/12/2012 9:23 am
Superb...I train a lot, as well as commuting. Shift work means that I prob don't have access to regular meals so was thinking of adding a protein drink into my daily intake.
Confused as to when I should take it - add it to a 1 litre bottle of water and sip throughout the day ?...or should I be using it before and after each session.
AS you can see - totally new to this 😆
Posted : 18/12/2012 9:27 am
Have the chocolate stuff with milk, actually very nice, just like a chocolate milkshake.
Posted : 18/12/2012 9:39 am
If memory serves, there's a 20 minute golden window after your session when it's best consumed*, so just bash it down. I used to use plain whey protein mixed with water or fruit juice (these days, as I'm a fatty, I'd skip the juice).
I understand that mixing it with milk causes absorption to be slowed, as the main protein in the milk - casein - is taken on more slowly**.
*This may be bollocks, so please check with more reputable resources..!
**See * above for qualifying statement..! 😀
Posted : 18/12/2012 9:44 am
As above, use it after I've done a lot of miles( 30+) as recovery drink. Don't mix it and sip it all day, but rather drink after exercise. And if I remember correctly, once mixed, should be consumed then and not left for ages.
Posted : 18/12/2012 9:45 am
Macavity's links are good summary's.
Try Recovery XS from MyProtien becuase it also contains Vit C and nutrients for rehydration as well as protien & carbs in balance so is ideal for cyclists recovery.
Posted : 18/12/2012 11:07 am
