What's wrong with m...
What's wrong with my Calor gas stove?
5 Users
We have a little Calor stove (two burners + grill). The last time we used it all was fine, however this week one of the burners isn't working correctly. The gas isn't coming out with a blue flame – it's about 50/50 blue and yellow and it's not a regular pattern around the ring. The outcome of this is that it is sooting up and leaving a mess on pans and on the burner. It does the same thing irrespective of how many burners are being used. Before I start taking it to bits, is there anything I should be looking out for? Thank you.
Posted : 29/07/2022 11:48 am
IT need a prick.
Posted : 29/07/2022 11:50 am
Clean it. Liberal application of brake cleaner to rid the burners of crud (or just use a pick).
Posted : 29/07/2022 11:53 am
Ta - is it feasible to stretch this out to take a few hours in the garage with the music on? 😂
Posted : 29/07/2022 11:57 am
If needed, turn the tunes up ! Just leave it disassembled (and fixed) and fettle the bikes ! Then when needed just screw together.
Posted : 29/07/2022 12:02 pm
 mert
The gas stove in the caravan did this a couple of years ago.
Just took the top cover off the burner, blast of brake cleaner, quick clean up with a bit of tag and the point of a knife and back together.
Took me longer to find the right bit for the tiny little screws than it did to clean it.
Posted : 29/07/2022 10:21 pm
Ta – is it feasible to stretch this out to take a few hours in the garage with the music on? 😂
All day job that AFAIK.
Got to test it regularly to make sure
Posted : 30/07/2022 9:38 am
