Whats this Berlingo...
[Closed] Whats this Berlingo warning light?
15 Users
I've asked this before, ages ago, but forgotten the answer.
[url= https://farm1.staticflickr.com/980/40921750345_527cb105a2_z.jp g" target="_blank">https://farm1.staticflickr.com/980/40921750345_527cb105a2_z.jp g"/> [/img][/url][url= https://flic.kr/p/25m7EFK ]2018-05-01_08-44-06[/url] by [url= https://www.flickr.com/photos/martinddd/ ]martinddd[/url], on Flickr
'05 plate Blingo, the light comes on every so often, not for long, its red, just wondering what it is, i think its just a blip.
Ta.
Posted : 01/05/2018 8:49 am
looks like a radiator to me, but as it's right next to water temp I doubt it is.
Posted : 01/05/2018 9:00 am
Coolant
https://singletrackmag.com/forum/topic/whats-this-warning-light-on-our-berlingo-dash/#post-8138462
and no I didn't use the forum search, I was bored so googled and it took me to your original question.  Probably something to do with my sad browsing history 🙁
Posted : 01/05/2018 9:03 am
Looks like a casserole dish.  Dinner is ready?
Posted : 01/05/2018 9:04 am
It's the 'Gallic Shrug' light.
Something is definitely wrong, but if you have to ask what it is.....
Posted : 01/05/2018 9:08 am
It's check coolant.
If it's intermittent probably a duff sensor.
CheCk.manually.
The fact it's orange means advisory ie may be low.
The temp warning light only comes on when you get the coolant temperature up to dangerous levels and is red. Will be accompanied by a red STOP light and lots of beeping.
Posted : 01/05/2018 9:21 am
'Your life might as well be over if you are driving one of these' warning?
Posted : 01/05/2018 9:33 am
It means you need to buy another bike. Keep buying bikes until it goes off.
Posted : 01/05/2018 9:42 am
Coolant level warning. Mine used to come on if I was driving too fast.
Posted : 01/05/2018 10:43 am
 bbb
Coolant level warning. There is a bung with the sensor in the coolant expansion tank and this often needs a clean then it will be ok again. If the coolant level is ok, then this is probably just the case. If there is low coolant then you will need to check for a leak.
Posted : 01/05/2018 12:21 pm
"if I was driving too fast".
In a Berlingo?!
Posted : 01/05/2018 5:10 pm
more than 45 in a 60 triggers the warning light. judging by all the old folk driving them round here .....
explains why when i drive mine at sensible speeds i get folk pulling out on me unable to judge speed properly
Posted : 01/05/2018 5:16 pm
“if I was driving too fast”.
In a Berlingo?!
Terminal velocity in freefall is about 130mph...
Posted : 01/05/2018 5:22 pm
Many thanks for all the help. After a year or more of this coolant low warning light coming on intermittently, i finally got round to checking it out, guess what........... the coolant was low! All topped up & no warning light now!!
Posted : 02/08/2018 11:16 am
A year?
You win the 'will the engine blow before I check the coolant' roulette.
Posted : 02/08/2018 11:20 am
I had the immobiliser light on on my Doblo telling me the engine was immobilised, it only ever came on when actually driving. The light isn't in the handbook as I guess the only time it is supposed to be on is when it can't be on. This was followed by all sorts of random warning lights coming on at random times, the radio turning itself off and on a couple of occasions the whole electrical system shutting down when driving.I had originally suspected an earthing fault but in the end traced it to a faulty ignition barrel. No issues since that was replaced.
Posted : 02/08/2018 11:38 am
I had the immobiliser light on on my Doblo telling me the engine was immobilised, it only ever came on when actually driving. The light isn’t in the handbook as I guess the only time it is supposed to be on is when it can’t be on. This was followed by all sorts of random warning lights coming on at random times, the radio turning itself off and on a couple of occasions the whole electrical system shutting down when driving.I had originally suspected an earthing fault but in the end traced it to a faulty ignition barrel. No issues since that was replaced.
Is your car called Christine?  Does it repair itself after a crash?
Posted : 02/08/2018 11:46 am
It signifies that your credibility has run out.  Usually comes on as soon as you buy a Berlingo 🙂
Posted : 02/08/2018 12:21 pm
I guess I'm a bit sad, but that symbol isn't in my copy of ISO 2575 Road Vehicles - Symbols for controls, indicators and tell tails. and it isn't the ISO 2575 symbol for engine coolant.
So I assume it's made up, and therefore doesn't conform to the correct EU standard.
Posted : 02/08/2018 1:23 pm
It was all rather spooky Glenn, and rather scary when you lose all power when driving as the power steering goes with it.
Posted : 02/08/2018 2:16 pm
