What's going o...
[Closed] What's going on with my windscreen?
12 Users
Answer me this STW.
I have a new Kia Cee'd, which is a great car, but every time it rains a circle of mist/condensation appears on the inside of the windscreen at eye level, in front of my face.
It's about the size of a £2 coin.
It always appears in the same place, and is always the same size.
I have cleaned the inside of the windscreen (yet it always reappears), there is no sign of a crack or chip, and I have tried every combination of blowers/air con etc.
Posted : 05/06/2017 1:29 pm
Sounds like the windscreen has an air gap between the lamination layers, but I've not hear of that being a thing.
Take it back to dealer to fix?
Posted : 05/06/2017 1:31 pm
A cold spot like that is a sure fire sign of poltergeist activity. fact.
You have a haunted windscreen... A 'windscream'.
Posted : 05/06/2017 2:01 pm
Might be just water vapour from your breath condensing on the windscreen? Try not breathing and see if it still happens.
Posted : 05/06/2017 2:26 pm
clean the area better. Could just be that condensation is forming easier here than other areas due to surface irregularities?
Posted : 05/06/2017 2:48 pm
[i] Try not breathing and see if it still happens.[/i]..
or breathe through your nose and see if 2 appear...
I would have thought you would be able to see an air gap in the lamination in all conditions, and I wouldn't have thought it would affect condensation on the surface (the condensation is appearing on the inner surface of the windscreen rather than actually inside the windscreen, right?)
I would hazard a guess that there's some kind of anti-fog chemical coating applied during manufacture and they missed a spot... but that's purely conjecture!
Posted : 05/06/2017 2:53 pm
Are there any aircon vents pointing to this bit of screen? I get a similar but much larger area on my screen, but nowhere near my line of sight thankfully, when it's warm & moist outside.
Posted : 05/06/2017 2:56 pm
Not going to cause condensation.
I'd go for surface contaminant / roughness which just makes it easier for moisture to condense in that one spot, or some weird anomolous air flow issue.....
Posted : 05/06/2017 3:00 pm
Is it a prescription windscreen? The blury bit might indicate its bifocal - it'll come into focus when your tailgating someone.
Sit in the car and ask a friend to see if your head appears unusually large to oncoming traffic
Posted : 05/06/2017 3:20 pm
Classic STW. It's a sticker.
(Or at least, where a sticker used to be)
Posted : 05/06/2017 3:51 pm
You lost me after the first full sentence to be honest 😆
Posted : 05/06/2017 3:58 pm
Thanks for all the suggestions. Lots to think about. 🙂
Posted : 05/06/2017 4:04 pm
