I was looking for a book on Amazon, a coding book, and had a look at 3 options using the "look now" function.
I noticed that two of the books coding examples are exactly the same. Different books/authors/publishers etc. But the books are almost identical in structure, but it's the code examples that are exact.
One book has been around for a lot longer than the other.........so, would you maybe pop an email to the writer?
Seeing that 99% of coding is copied and pasted from someone else I can't see it as a huge problem.
If you see a white rabbit, follow it. You'll then be given a choice, red pill or blue pill.
Seeing that 99% of coding is copied and pasted from someone else I can’t see it as a huge problem.
Copied and pasted.
They're probably both copied from Stack Overflow.
Seeing that 99% of coding is copied and pasted from someone else, I can’t see it as a huge problem.
Copied and pasted, but with a slight modification that makes it my intellectual property.
Fair enough, cheers
Copied and pasted.
Copied and pasted but, as this seems to be symptomatic of the modern age, it is with an exemption for satire.
