What tyre for a Mot...
[Closed] What tyre for a Motorhome/Van?
6 Users
I need to replace the tyres on my motorhome, it's built around a Fiat Ducato chassis. Will normal van tyres do, or is a different type required because it's a motorhome?
Posted : 02/07/2012 8:19 am
Motorhome tyres are better, however they are limited in choices and are costly.
I tend to use quality commercial tyres and because the speeds tend to be lower, although the van is heavily loaded I have never had a significant problem.
Caution, buy a decent tyre - we found the cheaper Avon commercial tyre not stiff enough in the carcass to cope with the transfer of load into corners and it made the rear wayward!
Posted : 02/07/2012 8:29 am
We've also got a Ducato based camper. the service book specifies Camper tyres so that is what we had fitted. for reasons best understood by the manufacturers they have to be inflated to a much higher pressure and yes they cost a fair amount per tyre and I'm sure there will be plenty on here that will suggest sticking van tyres but when I've paid £xxK for the van i'm not going to risk an accident or invalid insurance to save a few pounds.
The challenge now is to try to wear them out rather than watch them dry out in the sunshine. already 2,000 miles in!
Posted : 02/07/2012 9:09 am
Another reason to buy camper specific tyres, or at least good commercial ones, is that they are resistant to developing flat spots if parked up for a long time.
Posted : 02/07/2012 9:20 am
dave360 - Member
this is the only difference really between a camper specific and a normal van tyre - the ride etc is worse with the camper tyre, but they can cope with sitting there at max load for months on end. never leave a camper with low pressures!
Posted : 02/07/2012 10:58 am
I keep winter tyres (van) on mine as it doesn't do a huge amount of miles so wear isn't really an issue, plus handling is loads better in wet/snow (Merc Vito so rear wheel drive).
Posted : 02/07/2012 11:08 am
