What MDPE connector...
[Closed] What MDPE connector to water meter?
4 Users
I'll be putting in a new MDPE 25mm supply pipe from my meter to a new stop cock in the house to a) replace the existing lead pipe and b) move the stop cock. What connector am I likely to need to connect this to the meter? Obviously I'll find out when I dig the hole, but it'd be nice to know in advance.
Posted : 10/02/2010 9:55 pm
 Bear
I suspect that if it is a modern meter it will probably have a short section of MDPE on the outlet side, then changes to your existing lead supply. Best to dig hole first though otherwise you will end up with a load of bits you may not need.
Posted : 10/02/2010 10:05 pm
That would be nice and easy then. Digging the hole first clearly is the sensible ting to do.
Posted : 10/02/2010 10:12 pm
bes.co.uk is good for fittings etc.
Just taken delivery of a load of MDPE stuff today. 24 hours after order. Good prices.
Posted : 10/02/2010 10:22 pm
ta
Posted : 10/02/2010 10:39 pm
 Bear
oh and second the BES site, use them loads good delivery times
Posted : 10/02/2010 10:53 pm
Prob standard 25mm pushfit conector as would think be a tail of 25mm pipe from meter conecting onto your existing lead pipe. Used either Plason or Philmac when used to do this kind of thing for a living. Get decent fittings as saw a lot of folk using cheap ones and were crap.
Posted : 10/02/2010 11:02 pm
