What good quality 1...
[Closed] What good quality 1/4″ Hex Socket + Mini Ratchet & Screwdriver Bit Set
29 Users
 Aus
I’ve a basic Draper mini 1/4″ mini ratchet which I tend to use a lot but it’s pretty loose and wobbly, and the bit set isn’t great. I’ve a ‘nice’ 1/2″ ratchet and it’s lovely to use in comparison!
What good quality replacement is there, for the mini ratchet and a bit set?
Posted : 20/04/2021 9:14 pm
I quite like my 1/4" Bacho set
This one but bought years ago from Still tools in Livingston.
https://www.toolstop.co.uk/bahco-s460-socket-set-46-piece-1-4in-drive-p18003/
Posted : 20/04/2021 9:16 pm
Halfords pro
Teng
Bacho
My top 3
Posted : 20/04/2021 9:22 pm
I've got a mini set by Bahco. It's lovely.
This one.
Bahco set
Posted : 20/04/2021 9:28 pm
I have that Bahco set too, it's good. Ratchet is quite short, which isn't really good or bad, but something to consider. Also had a couple of Teng sets, they're generally just a little bit nicer but more expensive.
IME best to do screwdriver and sockets seperately, combined kits tend to be good for one and give lip service to the other. Makita do a really nice little driver
Posted : 20/04/2021 9:30 pm
I’ve got the same set as kayak, not expensive and held up to harder use than I have expected. Would buy it again without thinking if I lost the old one.
My most used tools are a Facom Expert driver set with a Snap On 1/4 ratchet and extensions.
I don't do car stuff any more and this covers most of the motorbike and cycle work.
I have old Britool kit for the odd times I need to go big.
Posted : 20/04/2021 9:37 pm
Wera Zyklop Bicycle Set
Posted : 20/04/2021 9:47 pm
I've also a syncros one in the bikes toolkit. That's nice to use
Posted : 20/04/2021 9:52 pm
Agree on the separate screwdriver, the cheap ish Bahco t-handle one has been a life saver in terms of getting extra torque in things without using an impact driver.
https://www.screwfix.com/p/bahco-hex-t-handle-stubby-ratchet-screwdriver/993jf
Posted : 20/04/2021 10:08 pm
I saw recently a ratchet driver that’s been developed to fit a Leatherman multitool; it fits into the hex-bit socket, and allows the tool to be used as a ratchet driver, rather than having to keep turning it 360 degrees to tighten or undo nuts and screws.
Yeah, it’s actually a Leatherman product:
https://www.leatherman.co.uk/products/leatherman-ratchet-driver
Posted : 20/04/2021 11:17 pm
I bought this one:
Bosch 2607017160 27-Piece Screwdriver Bit and Ratchet Set (Extra Hard Quality, Drill Driver and Screwdriver Accessories), 45cm x 40cm x 25cm https://www.amazon.co.uk/dp/B0071IK9CI/ref=cm_sw_r_cp_api_glt_i_SH74DGR5EHFY8AQHHMDS?_encoding=UTF8&psc=1
It’s tiny and has 120 tooth ratchet, great for tight spaces.
I also bought a Halfords professional 1/4 inch as well, it’s lovely.
Posted : 21/04/2021 5:46 am
Ditto halfrauds professional set.
Was half price but its really well made and a bit of kit i look after and it will probably outlive me
The magnussen stuff is also pretty good now.
Posted : 21/04/2021 8:42 am
I have a Wera one like this https://www.screwfix.com/p/wera-zyklop-1-4-drive-bit-ratchet-set-38-pieces/572hg
It's nice although the ratchet is perhaps a bit too small
Posted : 21/04/2021 9:00 am
I have a
FACOM 21 PIECE 1/4" DRIVE METRIC 6-POINT SOCKET AND BIT SET - R.161-4P6
Brilliant little set,price has doubled since i bought mine 7 yrs ago.
https://www.ebay.co.uk/itm/FACOM-21-PIECE-1-4-DRIVE-METRIC-6-POINT-SOCKET-AND-BIT-SET-R-161-4P6/264446449452?hash=item3d923c972c:g:PiAAAOSwum1dZ5cD
Posted : 21/04/2021 9:18 am
I have this wera one.
Wera-Zyklop-Ratchet
Ratchet is a good size and its very well made
Posted : 21/04/2021 9:59 am
Also got the Wera Bicycle Set 1 recently - it's tiny, but perfect for bike fettling. Thinking of making a new case for it to make it a bit more portable - the supplied case is pretty bulky.
Posted : 21/04/2021 10:22 am
Another vote for the Halfords kit, mine gets used regularly and only had the bit holder replaced after the spring broke.
Posted : 21/04/2021 10:31 am
https://www.wiggle.co.uk/topeak-ratchet-rocket-lite-tool
Looks the same as my syncros kit. Tbf they're probably all the same.
Posted : 21/04/2021 10:32 am
Bahco 1/4" one for me too, use it all the time for bike stuff, it's a nice little set. Only complaint is that I had to add a 3 & 4mm hex bit, it only came with a 5 & 6mm. Got the Bahco 3/8" and 1/2" set for car stuff too, equally good.
Posted : 21/04/2021 11:45 am
I kinda see them seperately...
For pivot bolts etc. I keep a few sets of 4/5/6 and T25 Wera bits... (but basically best quality)
Ive also got Halfords Pro and a surprisingly good full socket set including deep sockets from Screwfix.
Then I have lots of odd ratchets, screw drivers and such and torque wrench and some Topeak torque bits (cos my brother gave em me) and a mini Bahco that's brilliant for getting into weird places like uppermost cable routing on the Mega frame where there is <1cm clearance.
If you have to do anything with JIT then the Vessel stuff is lovely... imported mine form Japan and came with a mini origami.
Posted : 21/04/2021 12:24 pm
Same Wera bicycle set here too. It's nice quality and I like it a lot as a nice thing to own but if I'm honest I don't use it all that much, habitually just using normal allen keys (also Wera, excellent).
Posted : 21/04/2021 12:34 pm
This. Just wait for offers, they come round more regularly than DFS. I think mine was like 40% off or something silly.
Curious. The one complaint I have is that the spring falls out every time you remove a bit. How easy was it to wangle a replacement?
Posted : 21/04/2021 2:04 pm
Mine aren't trailside kits but incredibly useful mini-ratchet and socket sets.
I've got an older version of this £35 Halfords set (think it has slightly more sockets). Must be 20 years old now and still going strong (though the case is held together with gaffer tape). Ratchet is getting a little bit loose.
When some of the bits wore or got lost I bought one of these Makita sets £20 at Amazon (screwfix are selling for £35?!)
and a comfortable spinner handle from Ebay for about £8. it's a small ratchet but that's actually really handy sometimes. The bits being colour coded helps keep it all get put back in the right place.
Posted : 21/04/2021 2:16 pm
Must not let an opportunity pass by to recommend what I have...
This is my only 1/4-only set - Stanley 1-13-906 bit and socket set. 12x9cm handy little box.
Posted : 21/04/2021 10:59 pm
@cougar
Went to the shop and asked for a new one, the guy got a new bit and swapped it for my old one. It's a lifetime guarantee so should be that easy. Can't remember if I had my receipt but even then...
I had the same issue until it broke, never had it again so I guess there may have been a dodgy run of them or they fixed the design.
Posted : 21/04/2021 11:15 pm
👍 helpful, tar.
Posted : 21/04/2021 11:48 pm
I'm a bit of a ratchet tart and have many in different sizes. Facom is probably the most jewel like but Halfords pro is great to use. That said 1/4" stuff is rarely tight and rusted on so you don't end up needing much to get nut off. I actually prefer and flexible handle. You can use the lever to loosen then fold it up to more like a screwdriver to spin the nut off
eg:
A tommy bar and extension makes sockets into a nice T-handle tool too (like this but with a longer extension).
Posted : 22/04/2021 11:02 am
Interesting post. Obviously Halfrauds is popular, but what's best Facom or Wera??? .........I'd go Wera, but I suspect those in the 'know' prefer Facom!
Posted : 22/04/2021 7:38 pm
Was using my mates ancient Elora ratchet in work last night, using it to get at a bolt head in a very tight spot. It was one of those ones without the switch which alters ratchet direction, simply push the square drive through the handle and flip it over.
Only about 70mm long , but ideal for tight spots and extra leverage can easily be obtained by slipping a bit of pipe over the handle.
If you are going to be using it for tight spots I would be looking at something like that.
Posted : 22/04/2021 9:27 pm
Interesting post. Obviously Halfrauds is popular, but what’s best Facom or Wera??? ………I’d go Wera, but I suspect those in the ‘know’ prefer Facom!
I’ve got Facom at work, it wasn’t my choice it was issued, and in all honesty it feels like cheap rubbish. It’s for ever breaking or the chrome plating flaking off.
My own tools are Wera, Bondhus, Bahco, Knipex, Beta, and some old Proto ratchets. I’ve got some bits of Halfrauds Pro and really like it.
I’ve also used the lifetime warranty on a 9mm hex bit socket that exploded when I abused it doing the brakes on a previous car. Walked in, said something like “that’s broke” to which the reply was “I’ll get you a new one”. No receipt or any arguments.
Posted : 22/04/2021 10:41 pm
I have the bosch one, linked to above, got it from amazon.
Can’t fault it, I think it was £20.
Handy AF.
Posted : 22/04/2021 10:48 pm
 jpal
I’ve got an older version of this £35 Halfords set (think it has slightly more sockets). Must be 20 years old now and still going strong (though the case is held together with gaffer tape). Ratchet is getting a little bit loose.
Sound like I’ve got the same prob 25yr old Halfords set. Same has happened to mine, one of the hinges broke and has had gaffer tape/ zip tie holding it together for yrs. I also have the same vintage 1/2 inch and 3/4 inch sets which seem to offer more sockets than the newer versions. I specifically picked the sets that were just sockets at the time preferring to have separate screwdrivers and Allen keys and also have the Halfords ratchet spanners and combo spanner set. They’re all excellent quality and have lasted for yrs. im only a hobby user now but I bought them for use when I was a forestry contractor and they were all in constant use fixing our machinery that broke at an alarming rate.
I’ve got a few wera screwdriver sets and one of their multi screwdrivers in a pouch that really useful round the house. I must get a set of their Allen keys. On fettling the bike I find the need for a long Allen key ended screwdriver for mudguard bolts under the fork steerer and behind the bb. Std Allen keys risk scratching the frame here.
Posted : 23/04/2021 7:47 am
