what cable for exte...
[Closed] what cable for external floodlights?
5 Users
looking to move some external 30W LED floodlights, what cable do I need to go with these?
http://www.screwfix.com/p/teetube-ip68-3-pole-in-line-cable-joint/92911
Posted : 18/05/2017 3:11 pm
Are they wall mounted?
Posted : 18/05/2017 3:15 pm
Fits 5-13mm cable.
Posted : 18/05/2017 3:23 pm
yes wall mounted,
yes know the fit
from the millions of choices in the screwfix catalogue what is the recommended cable for an external wall mounted fit?
thanks
Posted : 18/05/2017 3:27 pm
Well personally I'd just buy cores and stick it in 20mm plastic/metal conduit. Any cable will degrade over time from UV (even supposedly UV stable stuff). I also think it looks neater / more professional.
Posted : 18/05/2017 3:33 pm
I would just have used 1.5mm twin core or 3 core and waterproof junction boxes. You'll need to use something with a round profile ideally.
Posted : 18/05/2017 3:44 pm
It depends on the environment and whether you're crossing any gaps between buildings.
Footflaps suggests a sensible default, but it really does depend...
Posted : 18/05/2017 4:17 pm
PVC twin n earth shouldn't really be used outside, how longs the run?
Posted : 18/05/2017 8:47 pm
About 10 metres
Posted : 18/05/2017 8:54 pm
