What am I describin...
[Closed] What am I describing? (metalwork question)
10 Users
I need to get a small piece of metal work done for a project and I don't want to sound like a complete tool when talking to the fabrication place.
I an getting a metal 'tube' made that will be abount 7inches in diameter. It will fit around a slightly smaller diameter tube. This will be used to disguise some damage to the smaller tube but it is not structural, the new one is purely cosmetic. The larger tube cannot slide over the smaller one, it needs to be 'wrapped' around it. I am therefore asking for the tube to be split and flexible enough to do this.
You still with me? If so, this is the bit that I struggle with. I will need to clamp the new tube shut, I think this would be best done with a clamp a bit like you get on some older suitcase or storage boxes. It has a square metal loop that clips onto a hook, the whole things is then tensioned by pushing a lever down. It is the sort of thing you see on strong camera cases, the metal ones with foam inside them. It does though need to be curved to fit the shape of the tube.
Does that make sense, what is that clamp called?
Posted : 12/03/2013 11:28 am
 DrP
I googled 'suitcase clasp' and found the trail from there...
DrP
Posted : 12/03/2013 11:31 am
Not quite the same field, but I think you've just described a springform pan.
 DrP
SUITCASE LATCH works betterer.....
DrP
Posted : 12/03/2013 11:32 am
 kevj
If I understand what you require correctly, then I suggest you look on the [url= http://www.stauff.co.uk/ ]Stauff[/url] website for either a 7" OD pipe clamp or even an accumulator clamp.
These are available off the shelf and <should> fulfill your requirements. Slightly more robust than the clamp locking mechanism you describe though.
Posted : 12/03/2013 11:34 am
What you need is a split double standard transverse cyclic sleeve complete with a non-actuated retaining ringstrap, they come in both left and right handed modes, and are in all metric sizes up to 8 inches
Posted : 12/03/2013 11:38 am
The clamps are generically called over-center latches/clamps, or toggle latches/clamps.
Posted : 12/03/2013 11:39 am
suitcase clasp
springform pan
suitcase latch
OD pipe clamp
accululator clamp
I'm sure within that lot is the perfect product, thanks!
Posted : 12/03/2013 11:42 am
A lockdown clasp latch perhaps
or a drawbolt catch
Look at the[url= http://www.adamhall.com/en/Catches.html ] Adam Hall [/url]and [url= http://www.penn-elcom.com/default.asp?MC=01010101 ]Penn Elcom [/url]catalogues perhaps, they have all sorts of buckles and latches for flight cases and the like
Posted : 12/03/2013 11:43 am
Jubilee clip? Hose clip?
Posted : 12/03/2013 11:46 am
Duck tape?
Posted : 12/03/2013 12:38 pm
+1 for toggle latch. Check rswww.com, they'll have em.
Posted : 12/03/2013 12:45 pm
