Weird Light Fitting
[Closed] Weird Light Fitting
7 Users
New light fitting (on the right) clips in to a mount. There are no screws and the instructions are no use. Anybody know what I'm supposed to do with it? Solder the connection?
Posted : 08/09/2012 10:32 am
What, exactly are you trying to do - replace the mount on the left with the one on the right ??
Posted : 08/09/2012 11:38 am
As cranberry said, what are you trying to do? They are completely different fittings, one's bayonet, the other screw
Posted : 08/09/2012 11:54 am
I'm guessing that cable your trying to connect to is a two core with each core being multi strand.
The cable connection points are/look like 😐 |: one wire goes into one connection on each side. You use a flat screwdriver in the slot to open a spring loaded connector, replacing screw connections. I guessing that you know it uses a different bulb type ( screw thread not bayonet).
Posted : 08/09/2012 11:58 am
You just push the wires in to the new fitting. springs and friction hold them in place.
Posted : 08/09/2012 1:21 pm
Push fit, eh. Never seen such a thing. I'll have another look at it. Thanks for the info.
Posted : 09/09/2012 8:50 pm
yep just push em in
where have you been hiding 😉
The center lug in the fitting should be live
Posted : 09/09/2012 8:55 pm
If you have never seen such a fitting should you be doing electrical work?!
Posted : 09/09/2012 9:33 pm
Get a grip, man. It's only a light fitting.
Posted : 16/09/2012 10:12 pm
