Weather forecasting...
[Closed] Weather forecasting question - BBC weather
8 Users
^ Screenshot of BBC weather, Monday's tab selected. The overview states a 20mph wind, the detail says at least double that. Which do I believe?
I'd accept "wind at 20mph with gusts up to 45mph" if it said so in the summary. But it doesn't.
Posted : 31/01/2016 4:19 pm
The black circles mean peak wind speed in gusts.
Posted : 31/01/2016 4:28 pm
Scroll down the page and click the 'pressure' tab on the map.
That'll give you a good idea as to what they mean.
Closely packed isobars (lines of pressure) = windy.
Generally, the indicators in your screen shot will show max wind speed.
EDIT: Eloquently put johnners
Posted : 31/01/2016 4:29 pm
[quote=wordnumb ]
Nonetheless, that's what it means
http://www.bbc.co.uk/weather/features/31666545
The written description will be for a pretty large area (e.g. mine covers the whole of the Highlands and Islands). The table above it is more specific to your location, hence the disparity.
Posted : 31/01/2016 4:30 pm
It also says 13*c but I can't see what time of day that is
Posted : 31/01/2016 4:39 pm
Fair enough. It's going to be a long ride home against that tomorrow.
Posted : 31/01/2016 4:52 pm
Solution - ditch the BBC and use yr.no or xcweather.co.uk
Posted : 31/01/2016 4:54 pm
Go straight to the gold standard - Met Office give both average wind speed and gust.
Posted : 31/01/2016 5:03 pm
Thanks - I had meant this to be a question about which less lazy, more accurate forecast to use. I find different forecasters are more reliable depending whether the location is in town or out country.
Posted : 31/01/2016 5:09 pm
wukfit - Member
13 is estimated highest temperature. It might reach 13C for about 5 minutes of an hour, and 12C for the remaining 55 minutes. You'd summarise that hour as 12C, but the peak of 13 would still be correct.
Posted : 31/01/2016 5:54 pm
