Watt bike atom in a...
Watt bike atom in an estate car?
7 Users
2 Reactions
Hello,
As so many Atom's are starting to come on line for sale would I be able to fit it in car, an estate in my case? Not worried about the weight as I'm a fairly hefty lump so can carry it.
Thanks.
Posted : 17/03/2023 10:25 am
pretty sure it would go in on it's side, they are quite compact
Posted : 17/03/2023 10:39 am
Caher reacted
I managed to get my Wattbike Pro in a Mercedes C Class estate, from memory I think I had to remove the seatpost and the base but it went in easy enough.
Very heavy and cumbersome things to move around, make sure you've got someone to help load it in and out of the car with you.
Posted : 17/03/2023 10:56 am
Caher reacted
they are quite small with the bars and seat removed. I can measure ours if that helps.
heavy buggers, although they do have little wheels.
would probably be relying on the seller to help you get it over the lip of the boot if you are going solo.
Posted : 17/03/2023 11:17 am
It'll be fine with seat removed. probably fine without it removed!
Sounds like a perfect excuse to buy a T6 though (l0l)
Posted : 17/03/2023 11:52 am
For some reason I thought this thread was going to be about bringing it to warm up at the start of races..😂
Posted : 17/03/2023 12:24 pm
it'll still not take off
Posted : 17/03/2023 12:43 pm
