Water powered bike
[Closed] Water powered bike
6 Users
But who reckons this guy is gonny go up in a big fireball anyday soon? 😀
http://uk.reuters.com/video/2015/08/11/brazilian-builds-water-powered-motorbike?videoId=365253395&videoChannel=82&channelName=Environment&utm_source=Facebook
Posted : 13/08/2015 1:17 pm
Will that fireball be the result of being doused in petrol and ignited by representatives of the big Oil companies?
Posted : 13/08/2015 1:23 pm
Oh FFS, are they going to report on my perpetual motion machine now?
It's not water powered. It's battery powered, through a convoluted (and inefficient) drive system.
I really wish news channels would either put a "Warning, this is science woo" notice on these pieces, or hire someone with a basic understanding of science to report on them.
Posted : 13/08/2015 1:25 pm
bencooper - Member
I was thinking that tbh. wonder what the point of the hydrogen bit if there's a battery in there splitting the hydrogen? Is there any point? would you likely get the same/more/less distance out of the battery alone?
Posted : 13/08/2015 1:26 pm
The advantage is you can burn the hydrogen in a relatively conventional internal combustion engine, instead of having to build an electric motor drivetrain. Makes even more sense if you leave the batteries at home, and take a canister of hydrogen with you - batteries are heavy, hydrogen isn't (though storing it adds complications).
Posted : 13/08/2015 9:28 pm
So the guy is squirting hydrogen into his carburettor? Seems like he'd be better off with a hydrogen fuel cell. I've seen some buses running on those.
Posted : 13/08/2015 9:44 pm
I've built fuel cell bicycles - fun, but complicated and not cheap! Also fun explaining to Air Products what you're planning to do with the hydrogen you've just bought from them 😉
It's a bit like the bloke who phoned me up a while ago, made me swear to secrecy, then said he'd worked out how to get a lot more range from his electric bike. "All you do is put a dynamo in the front wheel to charge the batteries!"
Posted : 13/08/2015 9:55 pm
Like for like yes but H2 is perfectly viable as fuel for any IC engine, you just need to get the fuelling right and build the engine strong enough. It's the storage that's the problem as ben pointed out, it's nowhere near as compressable as LPG and the like so you need huge tanks (a simplification but you get my jist).
Posted : 14/08/2015 3:02 am
 JoeG
and hydrogen has had some bad press in the past...
Posted : 14/08/2015 3:38 am
