As far as I can see it washes, drains and spins but the washing comes out soaking wet. The filter by the drain pump doesn't feel blocked when I have a prod.
Can't work out whether it's not draining quick enough or not spinning right?
Suggestions please.
Run a quick cycle with nothing in.. you should be able to see if it's draining properly..
Does it get up to full speed on the spin? Have you pushed a random button for gentle / no spin?
Jeff
I tried a drain'n'spin on a wet jumper last night and it was still soaking at the end. I didn't check to see if it got up to speed as there was much riding to be done.
I foresee an evening of sitting in front of a washing machine.
