VW Golf Turbo Noise...
[Closed] VW Golf Turbo Noise?
9 Users
Hi,
My VW Golf Mk 6 2.0 TDI 140 seems to have recently developed a whoosh/burpling noise when I change up gear at high (+2000) revs. The noise occurs when I depressed the clutch and only lasts about a second. Below about 2000 revs doesnt make a noise.
Any ideas before I take it to the garage? Its still under VW used approved warranty but want to go in there with an idea of what is wrong.
Posted : 14/02/2015 4:44 pm
I'd venture a loose pipe of some sort of someone fitted a stupid dump valve without you knowing 😆
Posted : 14/02/2015 4:57 pm
Dump valve stuck, pipe leaking or damaged.
Posted : 14/02/2015 5:26 pm
Split hose
Posted : 14/02/2015 5:28 pm
Revs dropping can produce a whoosh/suck sound from a holed exhaust too. Smart money is on a thing having a hole in it I think.
steveh - Member
That will have a VVT turbo, no wastegate on it
Posted : 14/02/2015 5:29 pm
Has your exhaust started to rot.
Didn't think diesels had proper dump valves as they don't have a throttle, and are therefore either at atmospheric pressure or under boost, but never a vacuum.
Posted : 14/02/2015 5:51 pm
Split rubber turbo hose.
Posted : 14/02/2015 7:06 pm
Agreed split hose
Posted : 14/02/2015 7:46 pm
