Volkswagen (20 reg)...
Volkswagen (20 reg) Android Auto connection woes
28 Users
20 Reactions
Recently got a new (to me) 20 reg Golf. It has the infotainment system that uses Android Auto hard wired via usb cable - I have a pixel 6a.
The connection is always fine at first but on longer journeys, say 1hr+ the connection just drops repeatedly. Unplugging and plugging back it it might reconnect, often just hangs "reading usb" and even if it connects, doesn't last long. I've tried a different (new) cable, but all other suggested troubleshooting is pretty standard stuff - latest version of app, different cable, clean out dust etc. Nothing meaningful. What I'd like to work out is how to know what's actually happening. Because it happens after a while,  is there a full cache issue on phone or car?
Anyone else had these issues?
Ideally as well I'd like to upgrade so it connects to AAuto via Bluetooth but I guess that's a hardware replacement?
Posted : 28/12/2023 10:09 am
 DrP
Not had this issue with VW... but i had similar in my LEAF..<br />The purchase of the AAwireless device solved it.<br /><br />Apparently it's something to do with (this is likely all BS!!) the voltage to and from going up the cable, can make some head units unhappy.<br /><br />AAwireless is more stable.<br /><br />regardless... it works, AND it's actually a ruddy fantastic bit of kit.<br /><br />
DrP
EDIT - down to £60 quid here...
Posted : 28/12/2023 10:18 am
If it’s dropping the connection and the cable is fine (new cables aren’t always fine) maybe check there’s no fluff in the socket on the phone
(actually - missed that you'd checked for dust - but yes - new cables aren't necessarily a solution as there are plenty of shite ones on the market so you've not necessarily eliminated that variable)
USB-C cables and devices also have a variety of data rate and power capabilities/requirements - clearly indicated by not putting any of that information on the cable or the device
Posted : 28/12/2023 10:27 am
Can you try a different phone?
Posted : 28/12/2023 10:30 am
 jimw
VW’s are notoriously picky about cables. I had exactly the same problem with my 2018 Golf and an iPhone, it has been cured by buying a VW branded cable (at a price). Hasn’t dropped out in the three years since I bought it so worth it in my opinion
Posted : 28/12/2023 10:45 am
This happens occasionally on my T6.1 van. I had a VW branded cable for 3 years until it went bad and started using the Apple one that came with my phone, that was Ok too. Now using an ikea one for a new phone and it seems OK.
BUT I think infotainment is a bit crap in some instances. Recently hired a T Cross for a week in Spain and the connection would never stay on, wired or wireless.
A while ago the van went in for a bowden cable recall and on the drive back from the garage the connection was on and off constantly, which does make me wonder of VWs connectors are bit rubbish (and had been disturbed)
Posted : 28/12/2023 11:30 am
I've got a 2019 octavia and have occasional issues with Carplay.
Nothing short of a full reboot of the head unit will see it talking to my phone when it does happen.
Using a crappy old/short cable which I am sure is to blame for some issues.
Posted : 28/12/2023 11:34 am
All the rentals I get when travelling have Android Android, and the most reliable cable I've found are the Amazon Basics braided ones. Have short USB-A and USB-C in my travel bag. Have always worked, in loads of different cars.
Posted : 28/12/2023 11:43 am
 Kato
I have a 70 Karoq with wired CarPlay.  Would drop in and out on a cheap cable, but has been fine since buying a proper Apple one.   Might just be coincidence though
Posted : 28/12/2023 12:14 pm
Interesting… I have an Audi A4 and the CarPlay does exactly that. It’s fine for an hour then disconnects at regular intervals. Have tried different phones and cables. Really annoying…
Posted : 28/12/2023 12:32 pm
Thanks all. Seems a new VW cable is first port of call, down from an eye watering price to just about acceptable with postage
https://volkswagenpartsuk.co.uk/parts/usb-a-to-usb-c-premium-cable-30cm/
Posted : 28/12/2023 12:42 pm
Make sure android auto is allowed full access/background use and no power saving
Posted : 28/12/2023 1:02 pm
I had almost exactly the same symptoms with a Nokia 6.1 (also, it got bloody hot). It was a lottery as to whether it connected at all. I switched to a Pixel 7a when the Nokia finally died and that's been solid on wired and wireless. Can you try another phone, a partner's maybe?
Might be worth jumping on VW's website to see if there's any firmware upgrades available for the head unit, also.
Posted : 28/12/2023 1:23 pm
 cnud
Depending which head unit you have, it's also worth a reset of the Android Auto module. This is under the factory reset menu on the head unit. This can cure a multitude of ills
Posted : 28/12/2023 2:16 pm
I have exactly the same problem, pixel 7a in a VW t6.1.
Works fine in my Skoda, but exactly as you describe in the van. It's hard to troubleshoot because it'll work fine on short journeys.
I took the short cable I use in the Skoda, where it works no problem, out with me in the van the other day, worked on a 70 minute journey no problem. On the way home, I switched back to the cable I have in the van which I know is problematic, but it worked all the bloody way!
The stupid positioning of the usb sockets in the van means I would like to use the longer cable really.
Posted : 28/12/2023 3:45 pm
From what I’ve read in various articles, VW are notorious for their shonky infotainment systems and poor communication with external devices. Relying on a mass of touchscreens doesn’t help either, which they’ve actually acknowledged and said they’re reintroducing actual physical controls. Doesn’t help the connectivity with third party devices though.
The Ford Sync system in my car can throw a fit and refuse to connect via BT on occasions, it can be made to connect by turning the car off along with the phone, but it’s just easier to plug the phone into the car, which you have to do anyway if you want to use the phone satnav, which I always do if I’m using satnav - trying to update the Sync system is a nightmare, and my TomTom app gets updated regularly anyway.
Posted : 28/12/2023 3:59 pm
@jimmy I have the same exact problem on my octy 18 plate. My guess is that it is to do with the phone reaching full charge.
My workaround is using an AA Wireless adapter Link which gives you a wireless Android auto connection, and if necessary charging the phone using a 12v adapter.
I don't believe this 1 hour problem is anything to do with the cables as I tried probably 5 different ones including some silly expensive ones.
Posted : 29/12/2023 10:06 am
jimmy and jimmy reacted
 DrP
If only someone had made a similar suggestion earlier... 😉
DrP
Posted : 29/12/2023 10:11 am
oldtennisshoes, jimmy, bruneep and 3 people reacted
DrP
If only someone had made a similar suggestion earlier… 😉
DrP
backing you up brotha!
Posted : 29/12/2023 10:21 am
geeh, oldtennisshoes, jimmy and 5 people reacted
 DrP
Ha! love it!!!
Far too much effort, will be wholly underappreciated...but 10/10 there!!!
DrP
Posted : 29/12/2023 10:45 am
I thought this might be the case, there's a setting in my pixel for "smart charging" which I turned off in case that had something to do with it.
But my pixel works without problem in my Skoda, but doesn't work in the VW, surely it would be problematic in both of it was something to do with that?
Posted : 29/12/2023 1:34 pm
If it is to do with with charging to 100%. There's a setting in Android which stops the charging at 85%, not sure if it would disconnect at 85% just like it does st 100%.
settings>battery and device care>battery>more battery settings>enable protect battery
Posted : 29/12/2023 1:48 pm
@cerrado-tu-ruido I don't have that setting in Pixel.
Posted : 29/12/2023 10:43 pm
Have problems on my SEAT Leon…have ordered one of @DrP’s suggested gadgets…..
Posted : 29/12/2023 10:51 pm
I don’t have that setting in Pixel.
Had a look, it's a Samsung thing, not Android.
Posted : 30/12/2023 8:43 am
Had occasional problems with wired Airplay in my 18 plate Passat (often no sound on initial connection), usually dived by disconnecting and reconnecting.
Wireless airplay in current car is worse - same sound issue but no easy way to disconnect/reconnect, also problems with sound coming via phone rather than car and mic not working.
Unfortunately I think the tech just isnt as good as it should be.
Posted : 30/12/2023 9:12 am
Same issue with Seat/pixel 7a. Seems as above to be related to reaching full charge. What seems to work is set an alarm beyond your journey and that triggers adaptive charging. But it's a ball ache.
Needs a software update.
Posted : 30/12/2023 9:22 am
 gray
ratherbeintobagoFull Member
How did you find the system in the Passat generally? I'm thinking of getting one but unsure whether 2018ish or 2019+ is better.
Posted : 30/12/2023 9:23 am
Pffftt!!!!!
My Vitara could be either the USB plug in the centre console, or the cable from that, to the HU.
Both are at least £60, and I have no way of knowing which one is faulty.
Anyone know if the AA dongle would work for me? Does it use the USB solely for power, and do the data transfer stuff via BT?
If so, I might invest in one.
Posted : 30/12/2023 9:28 am
Try the different settings for how the USB connection works once you have connected your phone to the car.
If the android auto setting doesn't work, maybe the usb controlled by connected device will work.
Screenshot_20231230_104044_Settings
Posted : 30/12/2023 10:45 am
@gray It was fine, could have a map repeater in the smart display, and the system was definitely better than the one in my wife’s 66 plate Golf.
I had the 150 1.4 TFSI and it was a great car, mainly got rid as it was accident damaged x2 (long story) and we got a good deal.
I’d have had the DSG if I was buying again though.
Posted : 30/12/2023 11:11 am
Yes, same issues, see https://singletrackmag.com/forum/topic/vw-androd-auto-keeps-crashing/
My current theory for more reliability is connecting the phone before starting the car or radio. Generally (clinging to a forest) this gets a more reliable connection.
Not tried a wireless connection yet
Posted : 30/12/2023 12:05 pm
 DrP
AAwireless unit just plugs into the USB port on your car. This connects and powers the device.
It connects to your phone briefly via BT, THEN maintains the proper connection via wifi. Takes about 8 seconds from turning on the car, to being connected.
Never have to take the phone out my pocket...fab
DrP
Posted : 30/12/2023 12:06 pm
My only issue with using a wireless unit is I use the phone to navigate through Android Auto so doesn't it need a clear access to the satellites?
Posted : 30/12/2023 12:20 pm
Is that really a thing? The only car I've had an issue with no satellite signal was a carbon fibre McLaren 😉
[Yeah I know, humble brag.... Except it's not mine, I just borrow it occasionally]
Posted : 30/12/2023 12:24 pm
Yeah, just duct tape the phone on to the roof. Blue tooth still works fine. The only issue is that you can't charge your phone unless you have a long cable.
Doesn't everyone do this?
Posted : 30/12/2023 12:32 pm
With the Nokia I found the opposite. Plugging it in started to initialise the AA connection then turning the ignition interrupted it, often sending it daft.
My only issue with using a wireless unit is I use the phone to navigate through Android Auto so doesn’t it need a clear access to the satellites?
It'll be using the phone's GPS receiver regardless of how it's connected to the car. It's not hooking up to a satellite via Wi-Fi or picking it out of the sky with the front-facing camera.😁
I just second-guessed myself here and checked. There's a lot of conflicting (and old) information out there but seemingly Android Auto will try to use the car's GPS antenna if the car allows it. In any case, the GPS connection is unrelated to how it's connected to the car.
There was a time where TomTom type add-on devices had issues with some cars due to some sort of coating on the windscreen (Citroen jumps to mind). But technology has improved and in any case, I'd expect any car natively supporting Auto to have taken that into account by design.
Posted : 30/12/2023 3:10 pm
Never have to take the phone out my pocket…fab
Sod it. Ordered one.
Doesn't list my car specifically, but there are other models that use the same HU that are compatible, as well as Maruti Suzuki (India) where it is listed, and also the same HU
Posted : 30/12/2023 3:18 pm
These were being raved about on a Audi owners group
I need to sort something out & will probably take a punt on one.
Posted : 01/01/2024 8:11 am
@snaps for the sake of £20 posted I took the punt. Just arrived, initial connection seemed a bit shaky but it works. Only thing it doesn't seem to do is pick up voice commands, which is a bit of a trade off but for quicker regular journeys it'll do the job. Thanks .
Posted : 20/01/2024 11:31 am
Edit: tell a lie, it does still pick up voice commands
Posted : 20/01/2024 12:52 pm
I've found a 20cm cable which I managed to test on a couple of longish journeys and the connection didn't drop once. Only problem is it doesn't reach to a convenient place to store the phone itself, unless I put the phone in the cup holder. But I prefer to use that for cups obviously.
Posted : 20/01/2024 1:05 pm
Off the back of this thread I bought a Motorola MA1 which connects pretty instantly and has solved the cable connectivity issues but now on long journeys I find the battery draining as I don't have wireless charging in the car.
Posted : 20/01/2024 2:29 pm
Anything stopping you from plugging it in to charge anyway?
Posted : 20/01/2024 4:07 pm
What about a 12V USB adapter.  if you're using the only USB socket for the Motorola thing
Posted : 20/01/2024 4:34 pm
I have 2 USB slots in my car but I didn't want to faff about plugging in and out when driving or have to stop. Also when I did put the phone in I started 2 sessions and ended up with a duel screen.
Works well for short journeys.
Posted : 20/01/2024 4:45 pm
I thought the wireless charger would be a stand alone unit, and plug into that adapter. If not, the the phone, when plugged into that, probably won't connect to the HU, as there'll be no direct connection to it like the USB sockets
Posted : 20/01/2024 5:03 pm
Caher and Caher reacted
Ah got it. I'll try that.
Posted : 20/01/2024 5:08 pm
The Motorola MA1 appears to work for me too at the moment.
Apart from not charging (fixed using the cigi lighter) the only issue so far is when you have two phones getting in the car. Apart from turning Bluetooth off I've not sussed how to switch between the two
Posted : 20/01/2024 5:24 pm
Charging-only USB cables exist, if that's your issue.
Come to that, assuming your phone supports it, USB wireless charging pads exist too... 😁
Posted : 20/01/2024 6:11 pm
After this thread, I bought a dedicated VW usb cable - no connection drops since.
Also the wireless dongle on page 1 from AliExpress - works perfectly.
So seems like problem solved with options now for wireless or wired.
Thanks all.
Posted : 28/02/2024 10:38 pm
Just wanted to resurrect this thread in case someone comes across it in the future and finds it useful.....
I've had the connection woes as described, Google pixel 7a in T6.1
Recently got this cable
https://www.amazon.co.uk/gp/aw/d/B0CNP6NQTH?psc=1&ref=ppx_pop_mob_b_asin_title
Android auto has since been working no problem, including on several long journeys.
Although.... Get in the van this morning and will it connect!? No it bloody won't. Phone charges but otherwise will not connect and start AA.
Was just about to hit buy on a wireless dongle, but thought why not try a restart of the phone and hey presto, everything working fine again. Bloody technology.
I think the key thing is the data transfer rate, but anyway, can confirm this cable supports rapid charging and AA (for now) in a VW van. Or my van at least.... Maybe it won't work in yours (disclaimer)
Posted : 10/04/2024 7:52 pm
Pixel 6a and a decent cable never had any issues with AA. It would seem buy cheap buy twice.
Posted : 10/04/2024 9:11 pm
Not exactly - I tried 4 different cables in the van, all of which gave iffy connections, but all of which worked absolutely fine in my Skoda.
I now have another relatively cheap cable which actually works in the van.
The cheap cables aren't the problem, it's the bloody van!!
Posted : 10/04/2024 10:07 pm
If it makes you feel any better, it's absolutely shiiite on my Ford Kuga as well.   Probably a 30% chance it works on a given start-up.
Ford double-down on this because when AA won't work, the car's own GPS doesn't start up properly either, so using the onboard mapping is useless too.
It needs the driver's key to be taken outside the car, the doors shut (engine off)  and locked, 5 minutes waiting for everything to actually shut down, then re-open the car and start it up after no more than about 20 seconds.
Posted : 10/04/2024 10:22 pm
And again if it helps my Cupra has days when it will only connect with a Blue cable, then days when it really dislikes Blue and will only use Red….when it’s feeling purple and my kids have taken the cable out of the car is really annoying.
I have purchased cheap cables and expensive, it decides each morning as to what mood it’s in and only the correct cable for that day will work.
When it’s in a really bad mood it lets out an ear shattering scream and carries on until I’ve rebooted the head unit.
No idea how VAG have been able to get away with it. My dealer told me “it’s a known issue and a software update will fix it soon”; 3 years later and no update.
Posted : 10/04/2024 10:33 pm
