Very OT - petrol je...
[Closed] Very OT - petrol jerry can that doesn't smell
9 Users
As title really.  I need to carry 5-10L to run an unleaded camp stove & lamp, and the van stinks of petrol.  I imagine it's sweating through the cheap plastic can.  When I used to race 250s, I'd have around 50L of premixed Avgas in a couple of metal jerry cans sloshing around in the van and I don't remember it smelling so bad.  Are they the answer?  Something like this?
Posted : 27/04/2018 3:26 pm
I use metal cans now. as you say the plastic ones STINK.
I carry 25litres now and again in the back of the camper when i take the genny to events like the puffer. no smell....
yet when i used to collect 5 litres in the plastic can for the lawnmower the car reeks of it.
mines just cheap ones out of toolstation.
I think also alot of it is - using a proper funnel / spout and the metal not being able to absorb the smell like the fuel spilt onto a plastic jerry can - no matter how careful you are it always ends up with some splashed onto it....
Posted : 27/04/2018 3:38 pm
plastic cans are porous to petrol vapour.
We're not allowed to install long range plastic tanks under decks/in closed holds in the boats as you can end up with a concentration of explosive vapour. We have to use stainless steel (i.e. corrosion resistant) as metal tanks are not porous.
I find most metal tank nozzles systems woeful though and the spouts arent great for use with a funnel when full. I assume there are some better design ones out there that arent all Jerry can knock offs?
Posted : 27/04/2018 3:45 pm
EDIT this looks like a good option. Metal can with a decent flexy nozzle
http://www.halfords.com/workshop-tools/garage-equipment/breakdown-essentials/halfords-green-metal-fuel-can-10l
Posted : 27/04/2018 3:46 pm
That looks just the ticket Stoner, I'll try and get hold of one after work as we're off camping tomorrow.
Posted : 27/04/2018 4:04 pm
I've got one that looks just like that Draper, with a separate clampy-on nozzle with a bendy bit on the end, works a charm imo. No idea where I got it.
Posted : 27/04/2018 4:40 pm
Even a metal one you'll probably have a bit of petrol on the spout etc. and my wife grumbles a bit when one's in the back of the van. I try to remember to put the separate spout in a ziplock bag which helps. But they are better than plastic for sure.
Posted : 27/04/2018 4:49 pm
I always have a 20L metal jerry can in the van as the plastic. ones are really no good for long term use i always find they leak from the poor gasket.
Posted : 27/04/2018 4:53 pm
Keep a small can of brake cleaner with it to give the spout a quick clean before stowing away, my can has a metal spout with a rubber insert and it stinks if i don't clean it first before putting it into my van.
Posted : 27/04/2018 6:25 pm
An alternative is to buy Aspen 4 instead of petrol - it doesn't smell, it burns better in camping gear and doesn't have the additives that IC engines require. It is more expensive than petrol, but cheaper than Coleman fuel.
Posted : 27/04/2018 7:04 pm
Don’t buy cheap. Draper stuff is very poorly painted and rusts in an eye-blink.
Posted : 27/04/2018 7:07 pm
