I'm planning on carpeting the interior of my scudo with 4 way stretch carpet. I've been told that the recommended Temp should be around 15° which is gonna prove tricky.
Can I just run a space heater while I'm doing the job or am I gonna have to wait until it warnms up? Surely the firms that do conversions don't wait?
Any advice gratefully received.
Space heater will be fine as long as it's not a freezing day
Spray the carpet back and the Other surface well, the adhesive sticks very quickly
Assuming you've got the bulkhead out you could run the engine and get the heaters going for a while. Only problem with that is if you spray the glue inside the van with the doors closed then you will be overcome with fumes and have to exit the van rapidly losing all the heat in the process
(Voice of experience here...)
