using ac voltage pe...
[Closed] using ac voltage pen
2 Users
 DT78
have a few boards up and spot a really old cable (black henly) traced it back to an old blanked off round pin socket where behind the plate it is terminated in a choc block.
I am pretty certain these wires / sockets are long dead, however when I check it with the ac pen it flashes up 2 bar.  Normally it flashes 6 and beeps when on a mains circuit.  but it' showing something.
any ideas?  could it be picking up some residual voltage from a close by live wire?
I don't need to remove it but if prefer to.  any more conclusive way to test?
Posted : 03/04/2018 12:36 pm
 ffej
Those non contact pens are fine for a quick check, but i'd be putting a proper tester on there to double check before i started sticking my fingers in. A basic multi meter is cheap enough.
It could be an induced current from a live connection running in close proximity to the (hopefully) dead cable you're testing.
J
Posted : 03/04/2018 12:46 pm
 DT78
just checked the choc bloc with a multi meter.  showing 0.4volts and no continuity so must be induced current
Posted : 03/04/2018 2:16 pm
