Using a laptops DVD...
[Closed] Using a laptops DVD drive for transfer to Netbook
3 Users
Im looking to get a Netbook. However, I would like to install Memory Map onto it. Could I use my laptops DVD/CD drive to transfer the disc data across? and what sort of lead would I need if its possible.
Dont want to buy a seperate DVD drive for Netbook as I'll only be using it mainly for surfing web.
Thanks
Posted : 10/07/2010 4:43 pm
In short, yes you can, but it depends on the operating system as to how you do it, just use a network cable to connect both to a switch or just use wireless to connect to a router, share the DVD drive on the laptop and with a little bit of tinkering you should be able to see it from the netbook
Edit: actually why dont you just copy it to a USB stick as suggested below, hell of a lot easier, if its on a CD it cant be much more than 750MB anyway.
Posted : 10/07/2010 4:46 pm
you could copy the files from the laptop drive on to a usb memory stick/removable hard drive and then put that in the notebook. or if they are both on a network you could share the dvd drive, and then use it from the notebook.
