I am using three to four usb ports on my laptop at anyone time for djing, music making and and finally a dac. I would like to simplify the setup and just plug one usb line in using a powered usb hub (most of the devices need power as well as data) what I am worried about is data loss in using the hubs and this effecting the audio streaming.
Please bare with me if this is a stupid notion I am no computer expert.
I dont understand - My Hubs dont have USB ports. Do I need to upgrade to King?
Maybee
Squirt some decent grease into the ports once in a while and you'll be fine
Never experienced any problems with through put of the data using a hub with audio devices. The biggest problem will be power like you mention.
Can you get them with 36 holes?
Can you power your lights from the USB hub?
usb hubs h shu b bsu bush sbu h hbs u
Thats a good idea - little dynamo inside the hub - USB connection to your lights.
Id patent that if I were you
Got one of those on my utility/touring bike. USB port is in the top cap. Dead handy, can charge light/phone/gps/etc.
back on topic, you should be fine with any decent powered hub. Might be less of an issue with a Mac than PC (if that's what you have) as Mac USB ports tend to be higher power anyway.
It would be powered with a PC just worried about the Audio streaming as it seems to be so easily effected by data loss.
how many audio streams are coming in and out at anyone time?
Two in two out.
