Up and over garage ...
[Closed] Up and over garage door, what paint??
9 Users
Normal gloss or is there anything a bit better for longevity? I'm heeding the comments when I post pics of bikes, etc....
Posted : 02/05/2017 9:38 am
I did mine in the Hammerite straight on to metal stuff, with a metallic 'hammered' finish. Took 2 coats (green on to white) but looks good although it's tricky to apply it just right so that it's thick enough to congeal in to the hammered look without running.
I could take a photo when I get home if you're really interested.
//edit - it's actually at the bottom of my garden next to the wheelie bins and bike shed, hence the decision for this style of paint. Might not be what you're after for a normal garage door, but I figured I wouldn't be able to achieve a finish with normal satin or gloss that I'd be happy with unless I used a spray gun.
Posted : 02/05/2017 9:45 am
I just went with the B&Q garage door paint. Went on OK but invest time with the preparation. I didn't invest enough and there were patches that it didn't take as well.
Posted : 02/05/2017 9:48 am
Depends what its made of. I would suggest as noted above preparation is key. For a really good finish you should remove all the existing paint, wash down with a oil and grease emulsifier and rinse. When completely dry use a specific primer for the base material then undercoats and top coats - I used two coats Dulux Weathershield over galvanised primer and it lasted over 8 years (until I changed the door).
Posted : 02/05/2017 10:14 am
I used Wickes exterior gloss for metal and wood on top of a micaceous iron oxide primer. Lasted well for a couple of years before I sold the house. No reason to think it's not still going as it was looking as good as the day I did it.
But as above preparation is the key, as it is with any paint.
Posted : 02/05/2017 10:45 am
Just finished scraping and hosing. I think the paint that's left on will stay put. So I'll let it dry and start. Can you get a primer / undercoat paint, or did I imagine that?
Posted : 02/05/2017 10:59 am
I used Wickes metal paint on a steel garage door after removing the loose, peeled old paint. Shortly after it peeled again and looked as bad as before.
In the end I used Hammerite garage door paint together with the recommended Hammerite primer. Worked a treat
Posted : 02/05/2017 11:37 am
Was is dark blue? Did you not bother with any prep at all? Did the guy next door have a lovely green garage door that he spent ages prep'ing and painting? Did I used to live next door to you? 😉
Posted : 02/05/2017 12:44 pm
Farrow and Ball exterior paint, as it happens.
Over a properly prepared and primed door, obviously. Just a shame my brother in law spilled paint on the driveway....
Posted : 02/05/2017 1:13 pm
I did mine in some 'outdoor' paint that was left in the garage when we moved in.
Preparation is key, for example - do sort out any peeling paint using perhaps, a random orbit sander.
If your random orbit sander decides to implode part way through, absolutely do not use a belt sander that was also left in the garage
A suitably thick coat of paint has not quite managed to cover the gouges left by said sander. No peeling though!
Posted : 02/05/2017 1:58 pm
Used Hammerite garage door paint to, didn't do much prep other than a quick wash, old paint wasn't peeling though just really faded. It's lasted 12 years so far and still good (but fading a bit)
Posted : 02/05/2017 2:02 pm
