Ubuntu wireless set...
[Closed] Ubuntu wireless setup help please!
3 Users
I've installed Ubuntu on this old netbook as it struggled on Win7 (and i'm fed up wrestling the laptop off the kids).
All well and good except I cant get wireless connection. It works fine when wired, and by fiddling with settings I get an icon that tells me i'm connected but I can't access any web pages. The icon is a bit odd though - rather than the radio waves it looks like a little telly with radio waves in it. I've no idea what this means, and can't find by googling.
Am I close to resolving this or on completely the wrong track?
Posted : 29/08/2012 8:51 pm
Linux is a bit funny when it comes to wireless drivers.
That aside, are you sure security settings etc are correct?
Posted : 29/08/2012 8:53 pm
I think so, I've matched the setup on the laptop as much as i could
Posted : 29/08/2012 8:55 pm
If you run a terminal session and run ifconfig it should show you all of you network cards and settings.
Does the wireless adapter show up and does it have an IP address?
Posted : 29/08/2012 8:57 pm
Ifconfig says:
knight@knight-Milano:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:03:0d:d4:61:22
inet6 addr: fe80::203:dff:fed4:6122/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:196823 errors:0 dropped:0 overruns:0 frame:0
TX packets:140090 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:268826921 (268.8 MB) TX bytes:11317893 (11.3 MB)
Interrupt:43
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:6381 errors:0 dropped:0 overruns:0 frame:0
TX packets:6381 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:494026 (494.0 KB) TX bytes:494026 (494.0 KB)
wlan0 Link encap:Ethernet HWaddr 00:24:23:09:8f:2f
inet addr:10.42.43.1 Bcast:10.42.43.255 Mask:255.255.255.0
inet6 addr: fe80::224:23ff:fe09:8f2f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:243 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:226 (226.0 B) TX bytes:52259 (52.2 KB)
Posted : 29/08/2012 9:12 pm
Okay so WLAN0 is your wireless link and it has an IP address. The next thing you need to do is establish if you have a default gateway and basic network connectivity so if you run the route command in the terminal it will tell you the default gateway.
Then run a ping to the default gateway address. If that returns okay you have basic network connectivity.
Posted : 30/08/2012 1:13 am
