We are rejigging front room and need to move everything to other side of bay window. Cables will need buried or taken outside and back in - Sky, plus booster connector wires etc.
DIY won't be happening, but if anyone knows an honest local pro that would be great.
Can you not just run the cable in trunking around the wall?
[url= http://www.screwfix.com/c/electrical-lighting/rigid-conduit-trunking/cat7230017#category=cat830578 ]like this stuff from screwfix?[/url] Stick it to the skirting.
Had wondered about trunking but hoping for less visible solution. Trunking probably most cost effective right enough.
It isn't as visible as you think. Get a small bit and try it out don't do what I did though and get the smallest diameter possible as it makes getting the cables in a real struggle 🙂 D shape, in white, on top of skirting looks ok. Are the floors wood? If so lifting a floorboard isn't too difficult.
Thanks. Floors are concrete, currently carpeted but about to be wood, so can't get cables under.
Also just thought can you remove skirting, and stick the cable in the gap at base of plasterboard, then glue skirting back on? Did this in the last lounge.
VanMan, had wondered about that option, will investigate behind skirting, cheers
No worries. If laying laminate you would be removing skirting anyway, or finishing with quadrant (which could be trunking). If going behind skirting add a couple of wall boxes to bring the cables out makes it neater than a hole and pipe cover 🙄 [url= http://www.wickes.co.uk/Wickes-Brush-Faceplate-1-Gang/p/204733 ] bit like this from Wickes[/url]
