Tumble drier vents into garage at the moment, which is a bit suboptimal as far as I'm concerned given that's where the bikes are kept.
Anyone know whether there's a reason not to cut a hole in the garage door for a vent?
Alternative is to go through the ceiling & attach to existing bathroom extractor trunk, but I understand this may fall foul of building regs?
Andy
Won't you have to remove it every time you want to open the garage door? If that isn't a hassle then can't think of any other reasons as long as the hole doesn't create a significant weakness in the door. Would it affect your insurance if they broke in that way and nicked your bikes?
You could always invest in a condensing drier, which means you don't need to vent at all.
As a "Vent", this thread is a disapointment.
You can hire a 102mm core drill [img] http://s7g3.scene7.com/is/image/ae235/39624_P?$p$ [/img] from your local builders merchant/hireshop and cut a hole in the garage wall. They will also have 100mm flexy duct and termination fittings to make a nice neat run and weatherproof the opening too. (or go to screwfix
http://www.screwfix.com/p/manrose-square-white-140mm-louvre-vent/14434 [img] http://s7g3.scene7.com/is/image/ae235/14434_P?$p$ [/img][img] http://s7g3.scene7.com/is/image/ae235/18561_P?$p$ [/img][img] http://s7g3.scene7.com/is/image/ae235/18232_P?$p$ [/img]
